Question about Hotpoint Ultima WF860 Front Load Washer
WMA66 Noise We have a strange noise in the bottom of the above. The noise does not relate to the drum turning but the noise seems different on different cycles.
  • les_watson Feb 16, 2009
    It only make the noise on the wasah cycle.
    I think it maybe a pump issue.
    Are there more than one pump on this machine.
    The moise is a sort of grinding crunchy noise
    Have run the macine again and its not a pump issue it a mechanical issue which when the drom sometimes stops and starts.
  • 135 Answers
Could you describe the noise plz?
Posted on Feb 16, 2009
  • pedropony2 Feb 16, 2009
    This sounds like a coin or similar object being thrown around by the pump.
    Your machine should have a filter behind the kick plate at front.
    Check this for the offending item.
    Thankyou for using Fixya.
Loud brake noise in 97 buick lesabre
When you had the drums off, did you inspect the shoes for excessive wear? And How do the drums look? Are they grooved? Can you be more specific about the loud noise. Does it sound like a grinding noise, or a screeching or pulsating noise. Is it lower pitch or high pitch?
May 04, 2014 | 1997 Buick LeSabre
Making a terrible noise
its cloged or the pad behind it is burned up
Jan 25, 2012 | LG DLEX7177 Dryer
I have a 2001 Jeep Grand Cherokee. I have a Whining noise in my front end area, seems to go away when turning to the left. Also I have a strange clicking noise mainly under braking, but when you have the...
This noise is more likely caused by the iiner constant velocity joint. When turning the axle makes a franction of an angle in which no perpendicular to the ground. You'll gonna need to have it check as there is a possiblity that the wheel drum or axle assembly might come off when driving in high speed to avoid accident.
Jul 03, 2010 | 2001 Jeep Grand Cherokee
Hotpoint WMA66 Drum Bearings gone. Drum will not ...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
May 20, 2010 | Hotpoint WMA66 Front Load Washer
Noise when agitateing wash only
Remove the belt, and spin drum by hand from inside, there should be little or no noise, if there is then it is possible the drum bearings are failing.
I f no noise, but there is when you put belt back on, then possibly bearing in motor noisy
Mar 06, 2010 | Hotpoint WMA66 Front Load Washer
My washing machine makes a loud banging noise wen it reaches the spin cycle only happens wen it is a full load not a half load
Form the front of washer, spin drum by hand, and if it fees rough, or is rumbling, then the main drum bearings are worn.
If no noise from drum, then could be worn shockers, or the washer is not properly levelled, or concrete balance weight, I'm afraid it is a process of elmination.
Hope this helps.
Jan 26, 2010 | Hotpoint WMA66 Front Load Washer
Drum is very noisy even when spun by hand
The drum may be off balance because a support wheel or bearing is not operating correctly. A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:
Oct 16, 2009 | Hotpoint WMA66 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
161 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
