Question about HP Officejet Pro L7680 All-In-One Printer
Print quality is terrible
I received a message that said to replace my black ink and I did. It says the black ink is now full but my printed quality is actually worse than before. When it prints, a few lines will look good then there will be a line that is fuzzy and cannot be read. The next few will be good then another fuzzy.Any suggestions
  • HP Master
  • 419 Answers
Your printhead is in need of a cleaning cycle...
The black part of the K/Y printhead is pigmented and they tend to clog much quicker than the other dyebase colours. As a result you should run a cleaning cycle from the control panel
  • Setup button
  • Tools option (6)
  • Clean Printhead (option 3)
That will then run a printhead cleaning routine which hopefully will resolve the issue.
Unfortunately as I said the K/Y printheads are poorly built and you may need to replace it if, after 3 cleaning routines the output doesn't improve.
One solution is to switch to a Non-HP black cartridge that uses dyebase ink instead of HP's pigment but that's only if you get this more than once.
Hope that helps.
Posted on Feb 17, 2009
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
Hello, i cant print\copy. i get a message about empty cyan and yellow ink but i only wanted to print in black. do i have to change the other colors to print in black (which is full)?
Check the printer options or settings, Click Print and then on the pop up window before you print, instead of color select print mode as black and white. Then try again and see, if it does print try removing the colored cartridge and see if it prints. If it fails again you will need to play around with the options and quality of the printout.
May 11, 2011 | Brother Office Equipment & Supplies
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
My printer was working fine, then it just started printing as if the ink was empty. I changed the ink cartridges and it will not print in black at all and the quality when it does print is terrible...lines...
since you already you did the correct troubleshooting still did not solve the problem. It means the printhead nozzle of your printhead needs of replace you need to call kodak toll free 1 800 421 6699 ext 05 and have your printhead replacement
Nov 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Printer will not print in black and white only.
The printer will not print unless you change the specific cartridge that is empty, so change the cartridge and install a full new one. then you should be ok
Sep 03, 2009 | Canon Pixma iP2600 Photo InkJet Printer
My incoming faxes won't print. both black ink cartridges r full
Is there any message when you try to print the faxes?
If there is an "Image Quality" message, probably the printer is set up to "Copy" in "Photo" or "Fine" mode and it needs to be set to something other than "Fine" or "Photo"
Apr 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
141 people viewed this question
Seeker5211
Seeker5211
