Question about Acer X193W LCD Monitor
MY COMPUTER CAN NOT INITIALIZE FROM BOOT, no working
I insert the cd system xp home ed. and woks from that cd and directly, places Windows Intall program.. then after that there is a dash like waiting and the...gives me 3 options:
1- install xp now then press enter
f8 accept license contract and click (no unit on your computer)
STOP 0x0000008E (0xc0000005, 0x8081c799,0xF7314778,0x00000000)
2- recovery console..... c: then it just give me Help but can not do nothing with cd either nothing
3 exit without intalling
others, do not know how i got there: Can not charge or the archive is corrupt (INF.txtsetup.sif)
setupdd.sys address F77BB98 base F7794000 Date stamp 41107C8F
Page_Fault_in_nonpaged_area
SOURCE: Acer AL1916W monitor
ive set that resolution but its still flickering on 60hz :S
i dont know what else to do. Ive installed new drivers for my graphics, ati radeon 9550..i dont know what else to do..PLS HELP ME!!!!
Thanx
Posted on Dec 14, 2007
  • 1019 Answers
SOURCE: Windows failed to start !...
Boot your computer with the recovery CD In the Drive.
You should get the option ** Boot From CD**
highlight click Yes, and overwrite the O/S.
This will re-install windows over your existing version, replacing any corrupt-deleted-missing Files.
mike @ compurepair.
Posted on Feb 24, 2008
SOURCE: acer AC713 drivers problem
I have lost my mother board cd,please give me a working solution.
Posted on Oct 17, 2008
freetek
  • 5568 Answers
SOURCE: Acer AL1716 Monitor Troubleshoot
You can try the following: - Early (very) in the boot routine tap either F5 or F8 to access a short startup menu - Choose 'Safe Mode' (this should give you some kind of display) If it does give you a screen; - Click Start - Select Control Panel - Open the System folder - Click on Hardware - Choose Device Manager - Find and open Monitors - Highlight whatever monitor is listed and delete it
With your monitor turned on and connected, reboot your PC.
I can't guarantee it but this may force Windows 'Plug and Play (or Pray)' to look for, find and then finally install some kind of driver (may not look like you want) to get your Desktop visible again.
Then you can adjust settings in the ontrol Panel's Display section.
Your monitor could be causing the problem but it is more likely Windows doing whatever it feels like (or nothing at all) again.
Posted on Nov 16, 2008
Alcatrazx
  • 65 Answers
Hello
You seem to know a bit about computer so I will give you a good detailed solution which might be of help. READ CAREFULLY
ASSUMPTION:
I guess that the main issue here is that your hard drive might be corrupted. I am also afraid that you might have erased or repartitioned your computer on a previous occasion if the recovery is not working. Please not that the Acer 5920 you mentioned has an automated system recovery system saved on to your hard drive. Did you by any chance Reformat the whole thing when you got the laptop? Because if thats the case and you removed the EISA partitions there is NO WAY you are going to get the recovery to work.
SOLUTION 1: USING RECOVERY CD's or DVD's
If you backed your system up when you first bought it and you created the CD's DVD's boot from them and recover the system that way. I am afraid that these will erase your C drive and will restore it to the original state when it was at time of backup. BEFORE all this you need to recover any data? In that case do the following:
1. remove the hard drive if you have important data.
2. Put it in a hard drive enclosure (which plugs in USB) and hook it up to another computer XP or VISTA doesn't matter both should work fine.
3. Then backup the folders you would like to make a copy of onto the hard drive of the other computer.
4. Then connect it back to the laptop (obviously make sure that when you remove and plug in this hard drive the laptop is off). And perform the recovery.
SOLUTION 2: If still all the above doesn't work.
If you do not need to backup anything there is no need to do the first 3 steps but you will need another computer
1. Do steps 1 to 3 above to make sure that you backup everything at least
2. Go to my computer on this to which you connected the drive computer Format the hard drive of the laptop (Making sure that before this step you backed up all the important data because you will lose it!)
3. Perform full format (this will take a while) and format it as NTFS, while formatting see if you can hear any funny noises. It could be a good sign that the hard drive is out. During format you should almost hear nothing. if you hear a repeated CLICK CLICK CLICK CLICK CLICK type of noise. Get another hard drive and repeat the above 3 wsteps
4. Get hold of an XP or VISTA installation disk according to what you had on laptop
5. Go to acer website and download all the drivers for the laptop you have and burn them on CD. If you already have a driver disc of the laptop you can skip this step but make sure that you have everything you need on it
6. put hard drive back in Acer 5920
7. Boot from the installation disk XP or VISTA. HINT KEEP the SAME OS if you had XP install XP ... if you had VISTA install VISTA
8. When it asks for serial number look underneath the laptop and key in the serial number from the fancy label you have underneat. It should be a 20 numbers and letters separated by (e.g. xxxxx-xxxxx-xxxxx-xxxxx-xxxxx)
9. Follow instructions and perform a full install
10. Now install all the drivers you have on that disk. These are like small programs. Install one after the other until you install them all. Reboot when asked to reboot... Do not choose reboot later!
11. Phew by now you should have a laptop working again. Isntall office antivirus and antispyware software and GET BACK the data from the other machine.....
CHEERS
Posted on Jan 07, 2009
Yes expert ntldr missing
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
Aug 18, 2011 | Microsoft Windows XP Home Edition
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
How do i install windows xp?
Insert the CD-ROM into your CD/DVD drive.
Restart your computer.
Tell your computer to "boot" from the CD/DVD drive, rather than to boot from the 'C:' drive.
Follow the on-screen prompts.
Oct 15, 2010 | Microsoft Windows XP Home Edition
How to boot windows xp home edition
insert it into your cd. restart the pc. when prompted press f2 or f11 for the boot options and select Boot from cd rom
Jul 31, 2010 | Microsoft Windows XP Home Edition
I qant to install windows xp
Get a bootable windows xp cd first.
Boot the computer and enter the bios.
Change the boot priority and make the computer boot through the optical drive.
Then save settings and reboot placing the cd in the drive.
The computer will boot through cd and show the main menu which allows you to format and install the xp select install and you will be able to do so
May 02, 2010 | Microsoft Windows XP Home Edition
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
Unable to Expand a Folder from my XP CD that I NEED!
Have you tried to copy the compressed folder from the disc to your computer desktop and open it there? Give that a try and see if it works.... I have had this happen to a couple customers at work and I just copied the folder from the disc onto the desktop, opened it there and re-installed it. Or you could also try a repair install of the OS but it does carry the possibility of losing your data and programs.
Jul 03, 2009 | Microsoft Windows XP Home SP3 Full Version...
Windows intall
plug in your your pan drive in usb then after take windows xp bootable cd put in your cd drive & boot from the cd rom drive
then after set will be start then after setup select partion option come during the installlation so select ther your pan dive drive
then after setup will format your pan drive then after finesh the full installation of the xp then after redey ur xp in pandrive
try & enjoy make shoure ur pan drive capsity mustbe higher then 2gb
Mar 24, 2008 | Microsoft Windows XP Home Edition
Acer X193W LCD Monitor Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
