Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Compessor will start and fill tank initally .
After it fills the resivor tank and tries to refill resivor tank ittrips off the cirucit breaker (power to the copressor))I think maybe a starting capacitor.As you have two capacitors mounted on top of the tank.Can i still purchase the capcitors.
  • ron_baillarg Feb 17, 2009
    Okay which capacitor as there are two mounted on top of the compressor.
    President:
  • 1,902 Answers
Yes it would be a start cpacitor and yes you can still order the part from sears
Posted on Feb 16, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 17, 2009
    Capacitors are cheap. When this happened to mine I just replaced both due to the fact that I found out that when I replaced the first one. 2 days later the second one failed. So I would recommened both. But it is the one closer to the power supply. I am sorry I do not remember the number to tell you which one it is. The start capacitor is next to the power cord though
I have a kobalt 236005 air compressor. It will fill the tank to 150psi properly. When it is time for it to refill the tank it will either trip the breaker or overheat the motor. It will not fill the tank...
Apparently you have a start capacitor, which acts as a surge tank to allow motor to start up under a load. Its usually a black cylinder shaped object with two [2] prongs with a wire plugged onto each one [1]. It can be tested with proper equipment, but should be reasonable to buy.
Sep 22, 2011 | Garden
When the tank is empyt the compessor comes on with no problem and runs until it's full, once pressure gets low the compessor should automaticly come on and refill, that"s when the compessor comes...
Hi mcfadden21...
Check and clean or repair or replace your compressor's unloader valve.
The unloader valve is suppose to discharge the compressed air from the tops of the piston heads to the outside to make it easy for the compressor to start when the pressure in the tank drops to the starting point.
Please take time to rate me thumbs up
Sep 15, 2011 | Air Tools & Compressors
I just put a new pressure switch on but when i fill the tanks the compressor wants to empty the air and it tries to kick back on to fill back up with air and some times it kicks and drawls a load on the...
Air leaking from tank back into compessor is indication that in-tank check valve is leaking. This condition will stress motor when trying to start. Test : With air in tank, unplug compressor from outlet and remove hose from compressor at checkvalve and test for leak (soapy water). If leaking drain air and remove checkvalve. Examine checkvalve for debris under seat (resurface seat or replace valve). Parts are at www.toolpartsdirect.com Good luck
Mar 10, 2011 | Hitachi EC12 145 amp 2Horsepower 4Gallon...
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
ROBINAIR 34788 NO MANUAL REFILL
You may did not open the tank valve before you press fill key! please try as bellow:
Connect tank fill adapter to source tank & open tank valve then make the tank up side down,now press tank fill key. screen will change to checking source tank for 30/60 sec. then start filling.
If you try as above direction & still the problem exist,it may need to replace or rebuild tank fill solenoid.
Jul 14, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you transfer new refrigerant to tank
Connect fill hose ( Black hose with 2/1'' quick connector located at near the tank strip) to source tank (New R134a refrigeration tank) & make up side down. switch on the machine power switch. Press main menu key then keep pressing up or down arrow key till appear "Tank Refil" on the display screen. with "Tank refill" on screen press YES key. the message will change to ''Checking source tank" for few second then start filling refrigerant to ISV tank. press NO key to exit when you want to stop filling.
Hope this will help you, Good lucl & vote for my solution!
Jul 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
My Neptune Top Load fills the water, the motor doesn't start.
If i understand correctly you are stating the breaker shut down which means the house breaker for the outlet power kicked out. You might try plugging something else into the outlet to see if it also kicks out, say a vacuum cleaner of a drill.
You need a amp clamp to test for something shorted or grounded (or ohm out windings) which requires trained service........you do not want to get a shock
Jan 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
1997 toyota 4runner. I flushed the cooling system. The heater blew hot air for a while. Now it blows coolair
check hose s make sure both hot. it not u have air in the lines. start engine cold remove rad cap and run car fill coolant to top of raadiator for about 20 minutes level will go down fill it up.. put cap on.. and fill resivor tank..
Oct 02, 2009 | 1997 Toyota 4Runner
After I drive 30KM, I got overheat for my 2000 Jetta VR6
just fill the resivor to the fill line hot or cold what ever the engine temp is. give it a try again
Aug 25, 2008 | 2000 Volkswagen Jetta TDI
Fill tank
ok on the bottom left side( from the front) is a magnet in the water tank. Sometimes that gets stuck and the sensor wants you to fill.
it can also be that the machine needs to be primed
Mar 27, 2008 | Saeco Vienna De Luxe Espresso Machine
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
139 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
