Question about Kenmore Sewing Machines
Thread breaks in reverse
My thread breaks every time I reverse stitch. I am not very experienced so I'm wondering if it's in my tension settings? I may not have them set right, with three curios kids in the house. I don't have a manual for this machine as a friend gave it to me.
SOURCE: thread tension
I have had this problem when the bobbin was wound wrong and also when the machine was improperly threaded. Check your manual to make sure you hit all the threading points, but I think the most common one i've missed that caused this was the metal loop you thread immediately before threading the needle.
Posted on Nov 13, 2008
bibleman01
  • 334 Answers
SOURCE: CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Posted on Jan 18, 2009
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
SOURCE: my white speedylock serger 1634 thread keeps getting in knots
i have the book and it says thread from inside out, inside looper (upper) then lower, then thread the needles, first right then left.  I have found that it does not matter if you thread the needles or loopers first but that you should try to thread from inside to out.
Posted on Feb 25, 2009
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
How do I reset stitching I can only sew 11 stitches at a time I have to release Foot pedal each time
if turning the machine off/on again doesn't clear the machine then it needs to be checked
Jan 24, 2016 | Sewing Machines
My bobbin and thread are constantly breaking. I have the correct thread to needle, but I don't even get one stitch before both break. Tension is on auto; should it be less or more?
is the needle in the holder the correct way ( groove in the needle facing the thread )
Is the needle eye the correct size for the thread in use
remove it from auto tension setting and adjust it your self
make sure that the top thread is between the tension plates and not around the thread behind the plates
the thread tension is close to correct when you need a bit of a pull to pull it along to the needle
is the method of threading to the needle correct as any areas where the thread reverses direction will cause it to break
what do mean that the bobbin is constantly breaking or is it the bobbin thread that is breaking
have you got the thread down the case slot and under the flat spring correctly
the bobbin has to be inserted into the case in such a manner that when the thread is pulled , it flows down the slot freely as the bobbin turns
if the direction is wrong , the thread has to move across the sharp edge of the slot and will cut easily
Dec 21, 2015 | Brother Sewing Machines
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How do you to keep the tension on older Singer sewing machine. Also, what causes the timing to need adjusting and is it something I can learn to do or do I need special tools?
Setting tension is a basic part of using a sewing machine that you can (and should) learn to do for yourself. Different threads, fabrics, and stitches sew best with different degrees of stitch tension. It takes some time to learn, but it is easy to tell when it is way off because there will be loops of thread from either the bobbin (lower tension) or spool and needle (upper tension). Generally, as long as your bobbin is threaded correctly, you will almost never need to adjust your lower tension. Your upper tension functions from a single knob, all you need to do is turn it a little higher or lower while testing your stitch on a scrap of the fabric you will be working with.
Timing is a more complex issue. Since you don't know how to adjust tension yet, I can jump to the conclusion that you are a novice, so I would leave timing adjustments to a more experienced professional. If the timing needs repeated adjustment, don't take it back to the same machine shop: if it is done properly, the timing should be fine for a long time, and some machine shops are unscrupulous enough to charge for repairs they did not do.
Oct 06, 2015 | Singer Sewing Machines
How do I fix a bobbin tnesion problem>
Bobbin tension is one of the biggest problems most sewing machine operators have. Check information sent for assistance on this.
Jul 23, 2015 | Sewing Machines
I have a Singer
Which stitch are you using?
To check thread tension for straight stitches, use different colors of thread in your top thread and bobbin. If the top thread shows on the bottom of the fabric, turn the dial counter-clockwise (towards a lower number). If the bottom thread shows on the top, turn the dial clockwise. Do not adjust the tension too much (for example, go from 2 to 2.5 if increasing the tension) at a time; test another set of stitches. Alternatively, you can adjust the bobbin tension in the reverse directions. However, it's very easy to damage the set screw in the bobbin case so do this as a last resort. Since this is a vertical bobbin case, put the bobbin in and hold onto the thread. If the thread moves when you dangle the bobbin case, tighten the screw. Loosen the screw if the thread doesn't pull out of the bobbin when you hold the unit.
For zig-zag decorative stitches lower the tension until the puckering stops. Usually the top thread will show on the bottom of the fabric.
If the tension is not changing when you turn the dial, make sure that the presser foot is down. The sewing machine may need repair. The tension mechanism depends on a spring and that can break. See the Singer site for a parts breakdown and contact your Singer dealer for the parts.
If the top and bottom fabric are not moving at the same rate, you can get a different type of puckering. You may want to get an even feed foot if there are several layers of fabric.
The manual for the 3116 is available from Singer: http://www.singerco.com/uploads/download/438_3116.pdf .
I hope this helps.
Dec 08, 2011 | Singer 3116 Simple
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Cannot machine quilt without the thread breaking and/or shredding. I've change needle, thread type and size and tension on my fabric.
If the thread is shredding and breaking, there is an incompatibility of your needle, thread, and fabric. Could be old, bargain bin, or poor quality thread--does the thread have little "hairs" of thread lint sticking out of it--that's probably not good quality. Look for fresh, good quality thread. Try a brand new needle--a sharp if you are sewing woven fabric. Make sure the thread is not too big for the needle eye. Sometimes, a top-stitch needle or embroidery needle will work well on FMQ. (A top-stitch needle has a longer scarf which helps protect the thread during the multiple times the needle penetrates the fabric before the thread forms a stitch. Shredding means the thread is getting worn out before it forms a stitch. A piece of thread penetrates the fabric 10-20 times before it forms a stitch.) Could also be a snag somewhere that is damaging the thread.
Sewing Needle Troubleshooting Guide
SCHMETZ Household Needle Chart
Most FMQ instructions say the upper and bobbin tension should be the same, however, I find my machine works a bit better when the bobbin thread is just a little tighter than the upper thread. Then the bobbin thread does not "pop" up on the top of my fabric quite as much. It's probably something you will just need to experiment with in getting used to your machine.
P.S.--when threading your machine, make sure the Presser Foot is ALWAYS RAISED so the top thread will seat properly in the tension disk. Failure to do this will cause thread barfs (usually referred to as thread nests or bird nests) under your fabric. Also, before beginning your FMQ, ALWAYS PULL the bobbin thread to the top of the fabric, then hold both thread tails gently in your left hand while you slowly take the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Mar 01, 2017 | Brother Sewing Machines
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
133 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
