Question about Miller RENEGADE 180 WELDER GENERATOR MIG 907395
Spool wire starts to melt while on the spool
I have a Miller MIG 90 I believe, purchased in the early 1990's, it is the model that was replaced by the Model 135.
I was welding one day, and wire stopped coming out. So I popped the hatch and found the wire had broken (or melted) before going into the liner. I did smell something hot, but I was welding, so of course things were hot. I set up the machine again and pulled the trigger. Once again the wire wouldn't come out. So I quickly popped the hatch and saw that the wire and several windings on the spool were glowing. It actually melted the plastic guide leading to the liner.
Any help is appreciated!
  • 33 Answers
You have a dead short.
take it to qualified repair center and dont kill yourself trying to find it.
not a phrase-dont be dead.
just take it to a pro.
Posted on May 09, 2014
  • 92 Answers
1] Switch off the mains power,remove the torch from the machine,ther should be a button or switch on the unit to feed the wire, push or switch these and observe that the wire feeds and dose not heat up, if ok then you have a short in the torch, a new torch assembly is required,if the wire heats up with the torch removed, the wire spool is shorting out, remove the spool and check wiring in and around the feed motor, if you can't see anything check for a voltage from a good earth and on the rollers, if you have a voltage then the motor is faulty.(earthing out) a P.A.T test should show exactly where this is.
Posted on Feb 16, 2009
My welder won't feed wire it sounds like it's trying to energize but can't. A couple of times it fed through but wouldn't feed to weld so I had stick weld. What happens if the liner has a restriction?
first unscrew the tiny tip at very end of torch (can be hot)!! then try to feed wire thru handle,gently shake cable as you do helps to feed wire thru cable , if successful you have allowed the amps to get too high for the feed rate (slow) and melted the tip closed , these tips are replaceable from miller and are not expensive
Aug 09, 2016 | Miller Multimatic 200 MIG TIG & Stick...
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    My wir burns up at the feed wheel before it goes to the sleve
    did you forget to reverse the wire .seems like I read that someplace . many newer ones thay added a switch for that purpose .
    May 07, 2015 | Miller Spoolmatic 30a Mig Spool Gun 130831
    I NEED A BREAK DOWN PHOTO/DRAWING OF THE WIRE SPOOL, ADAPTER, SPRING AND RETAINING NUT
    Follow this link...http://www.millerwelds.com/om/t225716g_pt_mil.pdf
    or copy and paste it at your web browser.
    Nov 05, 2010 | Miller matic 140 Mig Welding Package W/As...
    Millermatic 140 w/ auto set powers on but will not feed wire or arc
    If its a new unit its probably nothing. Miller makes good stuff. Open the side so you can see the spool. With the machine on, press the trigger for a second. Did the little wheel spin (trying to feed the wire) if it did then your problem could be kinked wire, **** on tip, or spring on small spool is loose and wire is slipping. Let me know.
    Nov 20, 2009 | Miller matic 140 Mig Welding Package W/As...
    I want to find a operator/owners manuel with a miller welders exploded repair diagram for 350P mig & spool gun
    get a hold of miller theyll be more than happy to help you,and turn you on to a owners manual.hope this helps jojogunn.
    Mar 15, 2009 | Miller Welding Tools
    Need wiring schematic for miller 140 wire feed welder
    No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
    Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
    Mig proplem
    Check the feed wheels at the wire spool make shure they are installed properly tight them if needed >>change tip >>
    liner may need replaced.>
    Dec 25, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
    Miller RENEGADE 180 WELDER GENERATOR MIG 907395 Logo
    226 people viewed this question
    Top Miller Welding Tools Experts
    Robert Lee
    Level 1 Expert
    Kory Ronning
    hubiam
    hubiam
    Level 1 Expert
    Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
