First you're going to need a slim psp, if you have it then you just plug the cables to the right places. To play games on your tv you need a tv with progressive scan and component inputs.
go to setting and look for the system settings option then go down to the format memory stick and that should create you all the files.then connect the psp to your computer and check that the folders are made
If your PSP isn't reading
games and/or movies and the problem isn't that your trying to play
dirty, bent, or damaged UMD discs there are a number of other reasons
your PSP is not reading disks correctly = - Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we
will get your PSP back to you and playing like like new fast! Our price
includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
First Tell me about your PSP firmware Version. If its a orginal SONY firmware you can't play the games from the memory stick. If you are in custom firmware follow this procedure.
1.press the SELECT button so you will get the M33 VSH MENU
CPU Clock XMB - Default CPU Clock GAME - Default USB Device - Memory Stick UMD ISO MODE - Sony NP9660 ISO VIDEO MOUNT - NONE
Make sure that its showing as per the above values. if not change it to the above values.
If still the problem continues check these too..
Go to the recovery menu.>>> configuration >>> Game folder homebrew (currently: 3.XX or 4.XX kernel)
if its showing 1.50 change it to 3.xx or 4.xx
also
Go to Recovery >> Advanced >> Advanced Configuration and make sure that both the options are Disabled.....
