Question about Minolta Compact Binocular
The central wheel between the eye pieces is frozen
The model I have is a Minolta MK 8 X 40. It is an old model and I dropped it and now it will not focus anymore. Is there anything I can do to repair it. The central wheel on my Minolta compact, 10x25 5.4 is froozen. What do I do?
  • mimiib Mar 23, 2009
    The central adjustment wheel on my Minolta Compact Binoculars 10x25is frozen. I did not understand the first solution. Please help me.
    It is helpful. I am frustrated because,I don't knowhow to get into the wheel, under the cover. I don't believe I have time, nor do I know where to get it fixed in the Phoenix area before I leave for South America on Friday
  • 142 Answers
You could probably get the wheel free on your own, but even if you do get that the binocular will have to be sent to a shop to have the lense tubes realigned. You don't necessarily have to bring it into Minolta. The process is a bit expensive.
Please remember to rate this fix.
Posted on Feb 16, 2009
    Brigadier General:
  • 3,917 Answers
Is there any ways to open the binocular. Please check the manual to open it and try to fix the wheel.
If it does not move then I am sorry but there would not be much help.
Posted on Mar 23, 2009
    Brigadier General:
  • 3,614 Answers
Well you need to send it for repair. could be a damaged on its part inside.
  • 153 Answers
Remove the gadget then dust the whell it wil be fixed
Eye piece lens detached
Find best compact bird watching binoculars for sale, best compact spotting scope that let you get closer to nature. Welcome to www.falconstare.com.
Aug 20, 2012 | Minolta Optics
8x25 minolta compact bionoculars center focus knob will not turn. Have taken screw off center knob and removed 4 rubber strips on bionocular body and looks like allen? screw underneath. No obvious way...
They don't make these things easy to take apart, or fix. Here's your best shot- take it into a camera repair shop, and see what they say. Some tech might know what you have to do to get it apart, or if it can come apart without damage or special tools.
Unfortunately, only the repair techs know how, and there aren't too many (if any) of them, since they often just charge a set amount and send a refurbished or new pair to the customer.
Wish I had a more specific answer, but good luck to you, and with just a bit, you'll figure this out.
Sep 20, 2010 | Minolta Compact Binocular
Hi guys i own a xregseat toledo 1.9tdi se mk2
either the lock mechanism is broke or the vacumn pipe is broke that lead into the door to operate the lock but this is only on older models .That have a pump in the boot
Dec 04, 2009 | Volkswagen New Passat Cars & Trucks
I have a minolta 404si. it recently took a fall and i dont no whats rong. there is no light coming threw the eye piece. the light meater keeps activating the flash. if i take the lense off there is light...
I suspect your lens is forcing the mirror up when it's mounted on the camera. This would cause a dark viewfinder and as the metering system is also in there then no light means that the camera thinks that it's in total darkness and activates the flash.
Try another lens. If the problem continues then the camera body is broken, if not then it's the lens. Most likely to be the lens though.
Used Minolta lenses are readily available at reasonable cost (or free if you ask on FreeCycle) so unless your lens problem is obvious and easy to fix then just replace it as spares are mainly non-available and labour charges are high. If you want a new lens then Sony retained the same lens mount when they took over Konica Minolta.
Sep 14, 2009 | Minolta Dynax 404Si Film Camera
Double vision in minolta binoculars
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Aug 30, 2009 | Minolta Activa Standard Zoom Binocular
sounds like you dropped it awful hard. if center wheel wont turn you must have. hard to say without seeing it,but check to see if x-bars are broken. good luck...larry@reichinstruments.com
Jan 14, 2009 | Konica Minolta Activa Sport (8x25) WP...
Missing the eye piece for the Meade saturn 60az-m
ebay is a great resource for eyepieces, i would suggest a 26mm ma.
the eyepiece should drop in. if not you might be missing the image erecting diagonal. when the eyepiece is installed you should be looking perpendicular at the tube.
Nov 25, 2008 | Meade 60AZ-M Jupiter Telescope 60mm...
Further info on eye pc view
The recording mechanism itself was damaged in the fall and that is why it can't record new ones and also sounds like the reason the eye piece is not working the only option you have for a high tech piece of equipment like this is to have it serviced I can help you locate local repair with your zip code(or city) or you can locate the closest authorized service center here:
http://esupport.sony.com/perl/select-system.pl?PRODTYPE=1,24,26,66,9,70,5,72
If you need any further assistance please let me know.
Thanks,
Lee
Aug 18, 2008 | Sony DCR-DVD101E DVD Camcorder
Minolta Compact Binocular Logo
238 people viewed this question
Top Minolta Optics Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Minolta Optic Expert? Answer questions, earn points and help others
