Question about KitchenAid KSRS25IL Side by Side Refrigerator
Never shuts off.Too cold
I have a Kitchen aid side by side model KSR25IL.It never seems to shut off.I have the temp set at 38 yet the refrig thermometer inside shows it to be 25-28 degrees.
  • Melissa341 Feb 17, 2009
    I cannot adjust my set point in either refrigerator or freezer. The refrigerator is currently set at 41'F and every thing FREEZES ! The water dispensor no longer functions- I believe its frozen!
  • AIMEE729 Mar 11, 2009
    5 year old KitchenAid KSRA251 side by side refrigerator in garage- I live in NJ, so most of the time my garage is freezing! refrigerator and freezer side freeze everything! temp settings read: 5 F freezer and 41 F refrigerator. Very little in the appliance. I have previously emptied it, uplugged it for a couple weeks, cleaned it- only to find the same problem after starting it up.
    16 yr. old Kenmore Refrigerator beside it works like a charm.
    help!
  • 150 Answers
Try defrosting.
if you can move everything out unplug ,turn it off w/ doors open 6 to 12 hrs this will free up any clogged tubes. Set it at a low setting and keep an eye on it, If this doesn't work your thermostat may be going out.let me know.Good luck.
Len West
Posted on Feb 27, 2009
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
Why is water leaking out of my kitchen aid frigs water dispencer?
Bad water valve, not shutting off all the way, replace water valve located on rear of refrig. Just follow water line from wall to water valve(may be by way of filter), unplug refrig from wall, remove rear cardboard or steel cover and you will see valve.
Oct 17, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Freezer & freezer work fine. Water stops when refrige is set at 38 degrees. To keep water from freezing we have to set the refrige temp to 40 degrees, but find that temp not cold enough. Water can...
It may have auto-defrost or frost-free feature that is not operating. Also there is a drain tube that goes from the compartments to the bottom of the fridge where the evaporator pan is. The tube may be plugged.
Jul 02, 2009 | Samsung RS2556 Side by Side Refrigerator
The fridge gets very cold even when I turned down the temp to #1
You have air dampers in this fridge.
Adjust them to a warmer setting.
Look along the left wall down low beside the vegetable bins.
If this does not correct the problem you have electronic temp sensors that have gone bad.
A technician will be needed to determine that.
Keep your fingers crossed that the damper is too open.
Any adjustment will take 24 hours to be noticeable.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
202 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
