Question about Sharp AL-1651CS All-In-One Laser Printer
Printer won't print even with newly refurbished TD cartridge
When "print" command is given, printer goes through a very long "warm up" type phase, then a red light flashes on the panel and the window message says "REPLACE THE TD CARTRIDGE". I took the drum to Cartridge World and they refurbished it. After installing refurbed cartridge the printer worked a time or two and then reverted back to the same original problem with the same message in the window. What do I do now?
  • Sharp Master
  • 13,433 Answers
I would suggest you take it back to them and complain about it since the work didn't last for more than few prints they haven't done the job properly.
Posted on Feb 16, 2009
    Brigadier General:
  • 3,614 Answers
Have you try unplugging the cable and plug it again.?
  • micromaster
    micromaster Feb 16, 2009
    DO a maintenance cleaning on the printer. it would be better to re install again the printer driver,
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of ideas you can try:
  • remove cartridge/drum;
  • shake vigorously to breakdown caked toner/powder;
  • wipe clean any metal contact strips;
  • insert back to printer in one switch positive movement.
Should this be not corrective:
  • reset printer by unplugging from the mains;
  • return unit to refiller (Cartridge World).
Good luck and thank you for using FixYa.
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Hello i have problem with old samsung...
considering the cost of new up to date printers I would consider junking it and get something under warranty that there are driver up dates for.
Sep 20, 2013 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Sharp AL-1651CS All-In-One Laser Printer Logo
200 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
