Question about ASUS P5GZ-MX Motherboard
Asus P5GZ-MX I had purchased AsusP5-GZ (945)it open very slow and take time to open windosin exesting 512 ddr 2 ram and after that I also attached one more 1 gb ( Starlite)hynex ram .but not atolfast what is the reason.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Did you perform a clean install of windows when you installed your new motherboard and memory?
  • 1,602 Answers
PUT THE LARGEST MEMORY STICK IN BANK0
PUT THE NEXT LARGEST SECONT OR IN BANK1
USE THE JUMPER SWITCH ON THE MOTHER BOARD RESET EVERYTHING TO ORIGNAL SETTINGS,
BUT BEFORE YOU DO THAT MAKE SURE YOU WRITE DOWN ALL HHD SETTING FIRST.
CHECK THE BOOT SEQUENSE OF DRIVE AND MOTHERBOARD.
ROD
Posted on Feb 17, 2009
Have asus p4s8x mob,when adding 3rd stick of memory (1gb) total of 3gb.computer hangs on startup 1long 3 short beeps. if i remove one old stick and leave new with old (2gigs total)it works fine,also works...
The Asus Asus Motherboards P4S8X-MX uses PC-3200 type memory and usually ships from Asus with 0MB of RAM. The Asus Motherboards P4S8X-MX supports up to 2GB of RAM. Maximizing your system memory will allow your Asus Motherboards to operate as fast as possible and offer the most productive environment.
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled, and for such systems we sell memory in a kit. Typically you will see 2x512MB or 2x256MB signifying you are purchasing 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Asus Asus Motherboards P4S8X-MX has 1 bank(s) which have 2 socket(s) in each bank for a total of 2 memory socket(s). This means the Asus Motherboards P4S8X-MX can support up to 2 individual RAM modules.
We recommend you purchase the largest capacity RAM module each time you purchase memory. The reason for this is if you decide to upgrade again later and all your memory sockets are filled, you will not need to discard the already installed lower capacity memory.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Asus Asus Motherboards P4S8X-MX.
Standard Memory Bank & Socket Configurationsocket_2.gif hope this helps John
Jul 01, 2011 | ASUS P4S8X Motherboard
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
Can asus p5gz-mx support 2gb kingston 800mhz ram
Click here to view the Specifications of your computer mainboard.
Unfortunately only 2 x DIMM, max. 2GB, DDR2 533/400 MHz memory modules are supported.
Meaning that it is not possible for the 2gb kingston 800mhz RAM to run, according to the Specs.
Sorry to inform you of this fact!
damnor01
Jan 23, 2011 | ASUS P5GZ-MX Motherboard
I'm looking for asus p5gz-mx driver.
http://www.bioticaindia.com/download.php?file=p5gz-mx
http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5GZ-MX-BIOS-0304.shtml
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Asus-P5GZ-MX-Realtek-HD-Audio-Driver-6-0-1-5350.shtml
http://www.nodevice.com/driver/P5GZ-MX/get55057.html
RATE THIS
Jul 14, 2010 | ASUS P5GZ-MX Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
Memory Issues with P5GL - MX
Some motherboards require that you install the memory in matched pairs. That could explain why they won't work together.
When you put the 1 GB in alone, what slot did you put it in?
I would suggest the blue A1 slot (closest to the CPU).
It may be that you have a bad memory module.
You could try the Windows Memory Diagnostic:
http://oca.microsoft.com/en/windiag.asp
You may also be interested in the motherboard's manual:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5GL-MX/e2222_p5gl-mx.pdf
Feb 06, 2009 | ASUS P5GL-MX Motherboard
Asus pp5gcx motherboard-realtek hd audio driver" failed to install"from cd.
go to the support site for your motherboard, there you will get universal bus architecture device drive. Install this before you install the Audio/Sound driver.
Apr 14, 2008 | ASUS P5P800-MX Motherboard
ASUS P5GZ-MX Motherboard Logo
216 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
