Question about Canon PIXMA MP810 All-In-One InkJet Printer
Flip up LCD Screen Pixma MP810 has distorted display
The flip up  LCD screen on my Canon Pixma MP810 display becomes distorted in the up position.  No words, just vertical bars.  If I move it down slightly screen displays properly.   I took it apart partially and noticed that the LCD screen is connected to an internal circuit board through a ribbon cable.   I would guess that one end of that cable is moving slightly out of positiion when the screen is in the full up position.  And connects properly when I move the screen slight downward.   I'm intent on fixing the problem myself.  What I need to know is, is there a source where I can purchase parts if I need to replace the ribbon cable or even the LCD screen? My email address is cwollam@aol.com.   Thanks for any help
  • Carl Wollam Mar 26, 2009
    I found a company in New Hampshire that makes flat ribbon cable. Their web address ishttp://www.wavelinkcable.com/contact.htm
    They had a 40 circuit wide flat ribbon cable in stock that I ordered for $10 and I cut it down to 30 circuits wide.   I installed the modified cable in my Canon Pixma MP810 printer and it works perfectly.
    Hope this helps anyone who has problems.  cwollam@aol.com
  • John LeFebvre May 11, 2010
    Thats a fairly new printer - can't you get it repaired under warranty?
    If not, then try to replace just the ribbon. I don't know where you could get a repalcement from however, unless you could buy another broken one perhaps and get enough parts to make one working printer?
5 Suggested Answers
SOURCE: Canon Laserbase MF5750 Multifunction
@all: Firmware Update
Download the Canon MF Update Tool from the Canon Homepage.
Connect your Canon Laserbase MF5700 series to your PC and flash the Firmware.
Worked at my Canon Laserbase MF5750.
Had the same problem like you.
Posted on Mar 12, 2008
SOURCE: Canon PIXMA MP160 error 27
My canon pixma mp 160 printer/ scanner is showing E 27, ink absorber is full need help please.
Posted on Nov 06, 2008
  • 33 Answers
SOURCE: Waste ink near full
Here is a link that provides info about this problem. hope this helps.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=10443#SupportDetailAct
Posted on May 03, 2009
damien729
  • 221 Answers
SOURCE: Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Posted on Jul 29, 2009
SOURCE: MP760 - how to disassemble? (waste ink absorber almost full)
You really don't have to disassemble it. What would be helpful tho is some sort of long needle-nose forceps. Tho I bet you could get by with a pointy chop-stick in a pinch. There are two waste-ink absorbers on the right, and one spongy thing on the left. With the 'hood' open, allowing you access to the cartridges, you should be able to see the pads. Get a Petzl light on your forehead, you'll need a lot of light! The sponge on the left is covered by a small clear plastic trough that channels the ink into the sponge below. With enough poking and prodding you should be able to get all these out, rinse with water, dry with a hair dryer, blot out the pad areas with a kleenex, and pop them back in. Good Luck!
Posted on Nov 14, 2009
Screen display problem on U-900
it could be the flex this is a common fault in sliding and flip phones take it to your local phone repair shop and they should be able to repair it at a low cost
Jun 08, 2010 | Samsung U900 Soul Cellular Phone
Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
Jul 15, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Screen gets distorted and turns white
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Apr 25, 2009 | Samsung SPH-m520 Cell Phone
The view screen on my Canon MP810 has lines across it when fully raised & can't be viewed. If the screen is only partly raised it is OK. Any ideas?
I just posted how I solved this same problem on my Canon Pixma MP810 printer. Check the FixYa problem site and see my solution.    cwollam@aol.com.
Mar 17, 2009 | Canon PIXMA MP810 All-In-One InkJet...
External display on pearl 8220 cracked
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Blackberry Flip 8220 LCD screen Replacement Guide
Mar 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Oct 14, 2008 | Canon PowerShot A630 Digital Camera
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
178 people viewed this question
old marine
old marine
Corne Viljoen
