Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Jandy lite 2 LG pool heater
When i turn heater on it lights like normal for about a minute then goes out? Pump pressure temp and switch on?
  • Anonymous Mar 17, 2009
    SAME PROBLEM CALLING JANDY TOMORROW FOR MY WARRENTY SERVIECE AGAIN!!!!
  • 22 Answers
Ignition control board failure
Posted on Feb 18, 2009
Heater will shut down within minutes of igniting and say heater cool down mode
what does water temp show if over 104 replace temp sensor make sure filters are clean if you have a heater bypass make sure it is at least half way closed or possible manual bypass spring broken or if gas pressure too low heater is sooted up and overheating
Jan 03, 2016 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 fl 7
Pressure switch will do exactly what you checked for, when the pump is not running. voltage on one side but not the other is normal when the pump is off. With pump on & operating, you should have voltage on both sides. One lead on the common wire at the transformer and the other checking the flow of electricity across the switches.
It sounds like your roll out sensor/fusible link is burned out. This burns out (open circuit) because of a "Reason"!!! The heater needs to be checked by a professional service company. Heat exchanger in most cases is Sooted & needs to be cleaned/desooted.
good luck
May 25, 2014 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
FL 7 is showing on computer screen. What does this mean?
Either the pump is not pumping enough water through the heater to activate the pressure switch, or the pressure switch or its wiring has failed.
Replace pressure switch .
Mar 23, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
I have a Jandy Lite 2 heater and I keep getting an error message FL 0. What can I do to get this heater working?
check the copper line to the pressure switch if ok check pressure switch should have 24 volts ac both sides if ok check rest of safety circuit
Aug 26, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater will not light main burner
make sure pressure switch is ok and the safety circuit if ok you might have a loose wire also check for cob webs
Jun 30, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 LG Model not firing up. Was working during day
ok 24 v at the transformer is yes than a safety swicth turn the heater off check fuses
Jul 10, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Heating problem with laars lx400 boiler
replace or adjust pressure switch to have heater go off when pump is off
May 29, 2009 | Jandy Laars Lt 400,000 Btu Heater
Laars lite 2 LG or LD Pool Heater- Heater won't stay on
the control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
Sep 20, 2007 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
550 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
