Question about General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge
Replacement 15A circuit breaker does not work
When the replacement breaker (that lights the kitchen) is flipped on, the kitchen light flickers but does not stay on.
  • dwlaba Feb 16, 2009
    Thanks for the quick response. Let me be more specific.
    When the breaker is flipped, the kitchen light does flicker, however, none of the electricity that is provided by that breaker works.
    The outlets do not provide electricity. None of lights are working.
  • 56 Answers
If the light is a flouresent light more than likely the ballast is bad. Very simple to replace but make sure power is of..Very common problem.
Posted on Feb 16, 2009
  • Pyldrvr Feb 16, 2009
    I the breaker is new try checking to make sure it is secure in the box. If you have a voltmeter you need to check to see if you have power at the breaker between the line and ground. If there is power then you have a open wire between the breaker and the source which is the outlets and lights. Check the first things first. Hope this helps you find problemotherwise you may need to get an electrician out.
My lights went out and now the stove doesn't work. How do I reset it.
Check your circuit breaker box for a 40 or 50 amp double breaker flip it off then back on should reset
Nov 05, 2013 | GE Adora JBP77SMSS Stainless Steel Kitchen...
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
Plastic clips that hold breaker in broke off
1) If this is for main breaker, then replacement is only option.
2) If this is for 120V or 240V breaker, then move breakers around so you can make space by adding tandem breaker(s) if available.
3) You can also make space by doubling lesser used circuit onto one breaker, making sure that 14 gauge wire goes on size 15A breaker and 12 gauge wire goes on 20A breaker.
4) You can work around by adding adding subpanel
Mar 02, 2011 | General Electric GE INDUSTRIAL SYSTEMS...
How many lights or ceiling fans can I hook up to one 15a single pole circuit breaker.
First of all, are there any other appliances or lights on this circuit? If so, they must be included in the total wattage for the circuit. The fan units are either listed with the Amp rating or wattage rating (Volt Amp) VA. The total amperage allowed on a 15 A circuit is 12A.(80% of the total per NEC). The total wattage would be 1380 watts. ( 115 Volt single phase X 15A = 1725 watts, 1725 x 80% = 1380 watts)
Jan 04, 2011 | Cutler Hammer Ch115 15a 1 Pole Circuit...
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
My dry quite working after my was work in electric box he was flipping power on and off
Your dryer is a 220 appliance and should be on a circuit all by itself. Are the items in your circuit box labeled (Lights? kitchen, etc.) One should be labeled "dryer". If you cannot locate one that is labeled for your dryer, Check out the position of the circuit breakers. If the dryer breaker is turned off it will be in the oppoite postion of the others.Caution: DO NOT do what he did and begin flipping breakers! If your dryer breaker is in the off position,is you should be able to flip it back on. Before you do this, have the dryer turned off.
If this does not work, unplug your dryer and leave it unplugged for 5 minutes or so, so that the dryers' operating system can reset itself. Then try turning it back on.
Dec 16, 2010 | Maytag Dryers
Had been having trouble with one or two burners, then today oven heating element was out and none of burners work although surface indicator light goes on, and circuit breaker has not flipped.
did you reset you circuit breaker by shutting it off all the way and flipping it back on? try it. some times a breaker will only trip partiallly.
or its possible you have a bad connection where the power cord hooks up to the range
Dec 10, 2009 | Roper FEP320 Electric Kitchen Range
Dash and shifter lights in 1996 jeep cherokee wont light
Hello and welcome to FixYa . Locate the dial that controls the brightness of the dashboardlights. If the control is not immediately evident. Make sure the brightness control is turned on. If it is and the lights aren't working, the problem may be a bad fuse. Check the fuse that controls the dashboard lights Replace the fuse if necessary. If just one part of the instrument panel is not lighting up, then you have either a burned-out bulb or a wiring problem.
Passenger side kick panel fuse breakdown for a 1996 jeep Cherokee Country
01 - 25A Rear Wiper/Washer
02 - 15A Radio, Cigar Lighter
03 - Empty
04 - 15A Passing Light
05 - 30A Blower Motor
06 - 30A (Circuit Breaker) Power Windows
07 - 02A ABS
08 - 20A Turn Signal Flasher
09 - 10A Radio/Clock Memory, Courtesy Lights, Glove Box, Cargo, Dome Lights, Telltales
10 - Empty
11 - 25A Headlamp Delay Module, Horn
12 - Empty
13 - 20A Power Door Locks
14 - Empty
15 - 15A Instrument Panel Lamps, Clock/Radio and Memory, Headlamp Switch, Parking Lamps
16 - 30A (Circuit Breaker) Power Seats, Trailer Tow
17 - 7.5A Instrument Cluster Gauges, Headlamp Delay Module, Chime Module, Overhead Console
18 - 25A Rear Defrost
19 - 05A Instrument Panel Lamps, Radio Illumination
20 - 5.5A (Circuit Breaker) Windshield Wipers and Washers
This should get you going. And you can always Ask Me.
Apr 27, 2009 | 1996 Jeep Grand Cherokee
Clock and lights work but burners and oven will noy heat turn on
Your wire connection from service panel to stove is corroded. It needs replacement. Check the length of the wires (three: two hots, and one neutral). Turn the breaker off first. Call me at at 757-454-2358 if you need anymore help. I don't get online often, so you need to call if you want anything clarify.
Jan 18, 2009 | Hotpoint RB787 Electric Kitchen Range
Not truning on
I would check your breakers again your oven breaker is a double one .. one of them may not be turned back on...
Apr 17, 2008 | Frigidaire FEF355 Electric Kitchen Range
General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge Logo
348 people viewed this question
Top General Electric Electrical Supplies Experts
Craig Butler
Craig Butler
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
