SYLVANIA LC200SL8 WILL NOT POWER ON
No power. Fuse not blown. Anyone know what might need to be replaced on the main board?
I have tested the power section and am not getting any power on the secondary side of the power transformer. Schematic that I found on the internet does not show Primary & secondary voltages for the power transformer. Anyone know what they should be?
Also, I took the board out of my Emerson LC200EM8 and connected it to the Sylvania LC200SL8 LCD screen and the screen and back light work, but there is a blue, line from top to bottom near the left side of the screen. I am not too worried about the blue line. I think I can correct that once I can get the main board to power up.
  • cmacko1 Feb 28, 2009
    screen turns on for about 2 seconds then turns off. lc200sl8 slyvania
5 Suggested Answers
SOURCE: Sylvania LC155SC8 remote TV code for Verizon Fios
buy the radio shack "6 in 1 remote. It has a "learning" mode that picked up all my needed commands from both my verizon fios remote and my new sylvania hdtv remote. works perfectly.
Posted on Apr 02, 2008
SOURCE: Remote Code for Emerson LC200EM8 LCD HDTV 20 inch
sony RM-VL600 remote, can be programmed remote to remote...I bought it, it works.
Posted on Apr 27, 2008
SOURCE: Sylvania 6632 LG blows fuse when plugged in
I too had this problem. I read some posts on this site about how to repair it, and low behold, they worked! I took the back off of the TV, and the first thing I found was the fuse was blown. With my meter, I checked the first 1N5406 rectifier diode after the fuse, and found that it had shorted out. Then I had to learn to desolder the diode, which I learned about on Youtube. I bought a pair replacement diodes at Radioshack for $1.49 and four replacement 125 volt 4 amp fuses. The whole repair cost about $5.00 and a few hours about learning about electronics. The TV works great! Good times!
Posted on Apr 08, 2009
SOURCE: RE: Dell W4201C
i have a Dell W4201C ,the picture Dims or picture blinks when channel changes
Posted on Jul 03, 2009
  • 458 Answers
SOURCE: ba71f0f01042 power board blows fuse
I'm not too familar with this model, but to give you some pointers, you will find when you have this problem the fuse will go straight away as there will be some of the semi-conductors short circuited. Check your bridge rectifier diodes & also the chopper transistor in the power supply. As a general check, test most of the diodes & power transistors & replace any that read short circuit on your meter. Hope this may help you as a guide line.
Posted on Aug 01, 2009
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Sylvania LC321SS9 B 32 LCD, won't turn on
Has this unit been near a lightning storm lately?/ Not that this is your issue. But I've had a T,V. do the same thing to me. I took it apart hoping it would be a blown fuse. But i was told a capacitor was blown out
Apr 10, 2015 | Sylvania Televison & Video
Sylvania LC321SS9 B 32" LCD, won't turn on
Hi Stephen,
TV won't turn on means the power supply section is dead. Open the back cover if you can. Check up for the blown fuse. If the fuse is blown, replace a new one of the same rating. If the TV works, enjoy viewing and if the fuse blows again consult some TV tech. Never try another fuse with higher rating. It might seriously damage your TV. Good luck.
Sylvania LC320SLX 32 in. LCD TV wont turn on
There is short circuited component/s at its main power supply regulator board. Check and replace them. It is best to replace the circuit board as card bassis, rather than trying to repair it.
Jun 13, 2013 | Sylvania LC320SLX 32 in. LCD TV
I have a sylvania LC200SL8 which went dead. Repair shop said it needed a new "Mother Board" (pn A7140UH) which I replaced. Still does not work at all. Any suggestions?
Power supply voltage outputs should be check first before anyhting else is replaced. I see that it has one main board which has the tuner, inverter, power supply all in one. What do get right now?
Oct 14, 2010 | Sylvania LC-200SL9 20 in. LCD EDTV
Monitor just went off. no power light. changed fuse but monitor is completely dead
possibly a power surge killed the main board in the LCD. if the fuse was blown i would suspect a power surge. you could replace the circuit board. either that died or the power supply died- depending on if it has internal or external power supply that might be blown as well.
i would take it to a professional LCD/ LAPTOP repair person. they should be-able to test it and let you know what needs to be replaced
Aug 06, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Ba71f0f01042 power board blows fuse
Aug 01, 2009 | Emerson EWL3706 37 in. LCD Television
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Sylvania 6842-PEM 42 in
If you are certain that the capacitor is OK, there could be a different problem on the main power board or even on the sub-power board. The sub-power board should have output voltages even if the main power board is defective.
Jul 17, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
263 people viewed this question
Top Televison & Video Experts
Electro Med Services...
