Question about Maytag Washing Machines
Maytag Neptune washer MAH5500BWW - water remains after wash cycle
Following a wash cycle there is water remaining in the unit.  The way you can tell is by turning the tub by hand and you hear the sloshing sound at the bottom.  No water is visible, but it seems the excess water is not correct.
aborcass
  • 2651 Answers
SOURCE: maytag neptune mah5500bww leaking water
i would check for holes in the boot assy , if so replace boot
Posted on Feb 22, 2008
dh1200s
  • 335 Answers
SOURCE: I need an instruction manual for Maytag topload washer Neptune TL
Get the Service Manual this will help you diagnose issues with this washer.  I found a Service repair manual on this site search for this; FAV6800 Manual.  Check the postings and you will find a URL to the manual.
From another member a step by step to dump water from machine in diag mode  ""One other thing I learned for those of you who don’t want to bail out the water in the tub. If you want to have the machine drain the excess water without bailing this should work. Turn the machine off and make sure the "locked door" light goes off. Then hold the "Spin" and "Enviro Plus" buttons at the same time for 3 seconds. "00" should then show up on the display. Then hit the "Delicate" button, then the “Pre-soak” button. This should activate the pump and get all the water out. Once the water is out hit the off button. You then may want to try the Spin cycle alone. These directions can be found on the Troubleshooting Manual found folded up behind the rear panel of the machine where the main electrical circuit board is located.""
Posted on Dec 15, 2008
aborcass
  • 2651 Answers
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
Posted on Feb 22, 2009
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
Illeagle
  • 525 Answers
SOURCE: My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Posted on Jul 17, 2009
Whybdoes water remain in machine at end of wash?
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
May 21, 2014 | Maytag Neptune Washer
I have a Maytag Neptune washer (model MAH5500BWW) that won't completely drain. It goes through the normal cycles but, but water still remains in the tub. Could the pump be out and how can you tell if...
Check the pump out flow of the drain hose, is it a good strong flow or does it seem weak and restricted. If the drain is slow the machine will stop before it is empty. Also if the drain hose is not vented, mounted too high in the air, or has a piece added on making it longer, it may degrade performance.
Mar 14, 2012 | Maytag Washing Machines
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Washer frequently stops cycling at 14 and 27 minutes remaining
I have the same exact problem... can't believe it's just me. I too would love to know what's wrong with this machine! Is their a recall for this???
Sep 04, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag mah5500bww washer
Unplug the unit for 5 minutes to reset the control. if the control continues to remain locked, this will confirm board failuer and, you will need to replace this control board.
May 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune is water suposed to remain after wash is complete
hi. thanks for the question .no not a lot, you cant get it all out. but you should not be able to see any. if you can see water. i would check the hoses at the pump, or a kinked hose. check that. thanks the appliance doc
Sep 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
