Question about Daewoo DVR-06
My Sony rdr-gx360 dvd recorder generates audio feedback. It is something of a strange situation as this does not occur when playing a disc, only when using a line input whether or not there is a signal coming in or even if there are no inputs hooked into the unit. Even stranger, the feedback stops when I open or close the disc tray or enter the system menu. I have changed out my cables, reset to factor default setting, rerun the setup and nothing seems to help. I am using an HDMI output to a Sony Bravia TV, and the feedback also runs out on the audio line out to my sterio. there is static when playing a movie,and the volume has to be tuned up very high for minial sound and louder static noise
rizla
  • 1463 Answers
SOURCE: Connection Nightmare
try here in this forum http://radioandtelly.co.uk
they will give you some ideas t oconnection set up .
riz.
Posted on Nov 02, 2007
  • 3 Answers
SOURCE: sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Posted on Dec 20, 2008
pgmadhav
  • 145 Answers
SOURCE: Sony RDR-GX360 unlock
Region lock is given to kill piracy. Please help to kill piracy.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
  • 5 Answers
SOURCE: have sony rdr-gx360. no manual
Try this - You will need remote.
After you have recorded video... (if you eject disk all will be lost)
- Push "Setup"
- Now push "Edit"
On left hand side it should now show "Finalize disk".
I also lost manual and took a few minutes to find.
Posted on Feb 19, 2009
SOURCE: disc tray will not open
I've not found one, no, but I have managed to strip the machine down, get the disc out and rebuild... I guess this is too late for you but it's simple enough if you're still trying.
Posted on Mar 28, 2010
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
Installing sony dvd home theatre dvd recorder to digital tv
you may have to press the audio button or set the audio stream on the dvd's (disc) menu, as some films use the 2 channel audio as default
Jan 02, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony gx360 stuck on dvd1
press and hold enter on remote... then, while holding the button (more than 3 seconds) press and hold down the number 1. after 3-5 seconds, things should return to normal.
Nov 10, 2009 | Sony RDR-GX360 DVD Recorder
Can't record movies on TV with my Sony RDR GX360 DVD Recorder
The movies you are trying to copy are "Copywrite Protected"
Mar 30, 2009 | Televison & Video
Disc tray will not open
Mar 04, 2009 | Sony RDR-GXD360 DVD Recorder
Dec 20, 2008 | Televison & Video
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Daewoo DVR-06 Logo
179 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
