Question about Code-Alarm Code Alarm Transponder
Alarm when i lock my doors of of my 2002 ford explorer i can go to the drivers side door and open it like it is unlocked but the alarm will go off and it is only the front drivers door how do i fix this
  • 227 Answers
When you use the manual lock switch on the vehicle you should see and hear the locks pick. When you use your remote you should also see the same results. If the drivers door does not respond with either you have a bad solenoid on the drivers door.
Posted on Feb 16, 2009
2000 Ford Explorer back door driver side door WILL NOT unlock
For this type of problem I recommend YouTube. Always a wealth of information on rear gates door locks etc.
Google > YouTube 2000 Ford Explorer door locks
Oct 08, 2017 | Ford Cars & Trucks
Driver Door Issues
Try replacing the unlock switch on door
Feb 20, 2013 | 1997 Ford Explorer AWD
98 ford explorer Driver side power lock button doesn't work
The button may be defective. Unlike the other doors, if you have the electronic group there is a separate driver's door unlock relay which reverses the door lock motor, probably to disable the theft alarm and allow your fob to open just that door for entry. This relay could be defective. The master switch operates through door lock and door unlock relays and those relays could be defective also.
Sep 07, 2012 | Cars & Trucks
Changed engine in 2002 ford explorer alarm system won't let start engine
if its a factory alarm put key in door and lock and unlock drivers door, then try to start,try that. good luck.
Nov 01, 2009 | 2002 Ford Explorer
I have a 2002 Honda Civic and for some reason the stock alarm wont unlock the driver door. I have changed the battery out and put a new one and still don't work... Could a fuse be out or do I need a new...
open all doors and press the keyfob to lock all doors then again to unlock them close doors and try again might work does for fords bmws renaults and vauxhalls the central locking may just bounce but should still activate all door locks when u close doors
Oct 01, 2009 | 2002 Honda Civic
2002 Ford Explorer - Drivers side door lock, rear
Aside from the fuses, your drive side power door lock may be failing to work because of a bad door-lock relay system, or, alternatively, the locking switch/button, itself, is not malfunctioning and in need of replacement.
A great handyman site that specifies the above probable causes and more is the following link:
Jul 18, 2009 | 2002 Ford Explorer
Locks not working properly
been there ------open up the rubber connector between the drivers door and the body [by the door hinges ] the wires break from flexing. just solder or **** connector them back together. it helps to add some wire to one of the broken ends to make it easier to connect . there may be more than 1 wire broken
Feb 14, 2009 | 2002 Ford Explorer
2002 ford explorer-alarm goes off in the middle of the one around Alarm goes of whenever it wants to. I don't lock my doors, because when I unlock them the alarm goes off and will not stop even...
At one point the door was lock from the in side and then closed and then unlocked with alarm, try un-locking it from the drivers door, then from the in side push the un-lock button and then close the drivers door. U should have no problems with it, but they do say that putting the key in the ignition and then do what you would like starting it but don't and do it 2 times and then start it will tell the alarm that it is not stolen.
Do u know that key less entry code to your drivers door?
Let me know if you would like your code that is if you don't know where to look.
Feb 01, 2009 | 1996 Ford Explorer
96 ford explorer door will not lock with switch
I do have a book on the 1996 but no on me but I have had a problem with it the same, Get in and sit in the drivers set and push lock from the in side and then do the same but this time unlock it and then get out and try to use the remote. if no then try to do the same thing but in the passenger side. lock and then unlock. no then call the ford dealer shop and they have a alarm department that will help you and I know because I had then do a job on one of my other cars and I was charged $20.00 he did it on a side job. Nikki2913
Nov 23, 2008 | 1996 Ford Explorer
Code-Alarm Code Alarm  Transponder Logo
171 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
