Question about Tatung V30DMTT 29.6 in. LCD Television
Need to replace power supply for Tatung V32GCGI
I need to replace the power supply in a Tatung V32GCGI is there anything special I need to do this? I havenot worked on one of these before and I don't have a repair manual for it.
Standby
Posted on Feb 28, 2012
    Sergeant:
  • 227 Answers
Just time and patience. If possible use a pencil iron. A gun is too much heat for the board. If you have the exact replacement be aware how the old one comes out.
Posted on Feb 16, 2009
TV TATUNG VC32GCG1- No picture or sound. Have checked all power sources to tv.
You already check the fuse inside near the power supply?Check also the power supply if they have power output.If power supply is good the problem is in the board.Need for repair and troubleshoot of authorized repair technician.
Jul 09, 2011 | Tatung Televison & Video
Tatung Power Supply Repair
Can u tell me very u live and whats pincode of your are so that i can solve ur problem..
Feb 06, 2008 | Tatung V30DMTT 29.6 in. LCD Television
I have a Tatung lcd flat screen monitor tv. The television comes on there is sound but the screen is black. The tv is 5 years old. What would cause this?
Failed backlight inverter circuits or the power supply for the backlight circuits has failed, you need to open it up and inspect the power suply first, look for bad caps with leaking/bulging tops. Post back what you find so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Power supply problem
As an electronics tech, you should know that replacement part information can only be obtained from the original manufactuer. A public "fix-it" forum is the least likely place for such specific information.
Have you tried asking at the supermarket? Of course not.
Oct 06, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Light goes green but no display.
Definitely Power Supply Board. Check carefully for open 1/8 watt metal film resistors. They wont show signs of overheating but they can be open anyway. I've never been able to find a print either. Once you do find open resistors make sure you measure for shorted components in the associated circuit.
Jun 15, 2009 | Tatung P46ACTP 46 in. Plasma Television
Tatung V30DMTT 29.6 in. LCD Television won't power on
bad power supply,common problem w/tatung,re-build power supply
Jan 04, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
Tatung V30DMTT 29.6 in. LCD... Problem: Faulty Power Board
Hi -I had the same problem with my tatung LDC tv. PIECE OF !@$#$#@#!!. Not knowing a whole lot about electronics, I decided well, I couldn't break it anymore, and I thought it was probably the power supply as the tv did NOTHING!!! it wouldn't light up make noise or anything. it was totally dead. I called around MANY, MANY local tv repair shops and NO ONE would work on this as they didn't have the repair parts for it. Thats what I get for going cheap. Anyway, well, I popped the back off, carefully making sure I knew where each screw went if I ever had to put it back together. Well, I located the power supply - it's pretty obvious, I removed it with a few screws and then found a company in california that repaired power supply's - I sent it off not knowing if it would solve the problem, but they quoted me $75 dollars and I figured if it didn't work $75 wasn't too much of a loss - and they said I could return it and get some of my $75 bucks back. So, I shipped it off to them. A couple weeks later, I got it back and installed it and to my amazement it worked!!! It has been working GREAT ever since. There is a few places online that sell the power supplies and offer a refund minus restocking fee if that doesn't work. Check out http://www.shopjimmy.com Good luck and hope this helps scott
Jan 25, 2008 | Tatung V30DMTT 29.6 in. LCD Television
Tatung LCD television
The power outage simply precipitates a pre-existing flaw in the power supply unit of this TV. You will need to either order a new power supply and put it in yourself, or send it to Tatung to fix. I had the same problem. Contact this person:
Vila Khamkathok
Customer services supervisor
Tel: 800-827-2850 x161
Aug 06, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Tatung V30DMTT 29.6 in. LCD Television Logo
362 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
