Question about Kenmore Elite 45986 Front Load Washer
Washer wont start unlees the button is held until it does start
Error codes...f...and ...dl
  • 121 Answers
Try to restart,turnoff machine wait few minutes and turn on .
Posted on Feb 17, 2009
Wont start
First you have to find the error code.
So! To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Dec 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
We have code e50 on the front off it how do you get it off
E50 is relating to the main motor,it could be the brushes,tacho or something more serious.That error code will not clear until you can find the problem causing it,try checking the brushes first.If you want to try to clear it first follow these instructions and you may get the exact error code displayed if so then get in touch again with the new error code.
Hold the start/pause and skip/reset together then press the on/off button keeping the other 2 buttons held until you get chasing lights,now release the first 2 buttons.Now press the fabrics button until the light goes down t60 degrees or the pump cuts in.Then take it on I think step by step until an error code displays make a note, to cancel hold the 2 buttons start/pause and skip/reset and the error code should go but if it reappears then the fault is still there.Good luck
May 03, 2010 | Zanussi ZWF1430W Front Load Washer
Washer code says dl? and wont start
"Fdl" is a door latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, if required, and the steps required to replace any defective parts.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
64 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
