Question about Toshiba Satellite A215-S7422 Notebook
My Toshiba Satellite A215 message Toshiba Flash card not working.
I need the Toshiba flash card to work because that is how I set up the laptop with the LCD. It opens fine sometimes but with every new update to Windows Vista it stops working and the message comes up again when I start up the computer again. Sometimes I can get it to work by trying to open to program right away on startup: I move my mouse up to the top of the screen repeately on startup to get the Flash Card to open up with the drop down menu. Last time I tried that, it didn't work either. I use this laptop quite often for LCD presentations. I also have a problem with a message "Toshiba flash cards is not working" on my Toshiba Satellite A215.
2 Suggested Answers
johnnailed
  • 36 Answers
SOURCE: My Toshiba Satellite A215 message Toshiba Flash card not working.
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
4s11
Posted on Jan 07, 2009
When i start my computer i receive message from window says ( Toshiba flash card is stopped).
Try:
Control Panel - Performance Information and Tools - Adjust visual
effects
"Use visual styles on windows and buttons" function on the very bottom
should be enabled to let the flash cards working
Feb 27, 2011 | Toshiba Satellite P200199
Bios does not recognize cd/dvd drive, nor external cd or dvd drives (optical drives). Updated to version 2.0 Bios from Toshiba website, but no success with that either. Is there a fix for this? How can I...
well, only way is to flash your bios.
it should be bootable flash bios tool that will assist you to remove all the current settings to the original settings. but if you can get the memory flash for toshiba then try running the system in safe mode the see if your usb devices can function then you try booting the system with cd/dvd drive. it should work
May 21, 2010 | Toshiba Satellite A215-S5822 Laptop
Toshiba a205 I let the battery go dead now all it will do is flash the blue light with the cord symbol what's that mean?
It means that there is not enough battery to supply the voltage the laptop needs to start. Simply let it charge overnight and it should be fine in the morning assuming the charger is working properly.
Apr 04, 2010 | Toshiba Satellite A215-S4747 Notebook
Toshiba flash cards stopped working
go to Toshiba web site. they have your problem solution.
Dec 20, 2008 | Toshiba Satellite A105 Notebook
Toshiba flash cards not working ??
It means what it says. There have been mentioned problems of this. You can disable the flash cards (>Start Menu-->All >Programs-->Toshiba-->Utilities-->Settings for >Flash Cards-->Disable Flash Cards) but you then apparently lose the function keys (therefor cannot change the brightness.) First off though you should perhaps state the model of your laptop. If it is the Toshiba A10/700 then I believe there is a Value Added Pack for download on the Toshiba's Canadian website - but has problems. I have also heard of programs causing such problems, such as Photoshop CS2. Is this message appearing after hibernate? If so what programs do you leave running?
Jun 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Flash Cards
if its under warranty then you need not worry, you should contact the service centre, but before going there make all backup of your important documents..........
thanks
iqbal
Apr 02, 2008 | Toshiba Satellite A205-S4607 Notebook PC
FN keys not working
Search "flash cards" on your computer. Several shortcuts will popup and you shuld see one entitled "restart flash cards". Double-click on this icon and then hold down the fn key to verify if the restart worked.
Nov 03, 2007 | Computers & Internet
Toshiba Satellite A215-S7422 Notebook Logo
202 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
