Related Tags:
This problem should be removed because:
Problem with Garmin Forerunner 305 GPS Receiver
Forerunner 305 battery
Is the Forerunner 305 a common battery that is easy to find?Hi
I have the same problem battery had it and don,t want to garmin for a simple job.
Does anyone know of a replacement
Solutions (7)
Hi and welcome to FixYa,
A possible replacement battery is available here and as shown below. The original battery has P/N 361-00026-00. The replacement would require a bit of modification on the power leads/wires.
Procedures would be similar to a 205 as illustrated here.
Good luck and thank you for using FixYa.
Welcome to Fixya !
There are TONS of Li-ion cell and mobile phone batteries as well as those sold to the RC hobbiest. Your best bet its to reach the nearest radio store and try to find a 3.7V Li-ion, 750 mAH battery with these exact dimensions (or smaller) and you will be fine. >305 battery dimensions:? H 33.5mm x W 35.0mm x D 5.5mm
Any battery with these specs should fit perfectly into your device.
Please rate the solution.
the battery is internal rechargeable lithium-ion. this is not recommended to be replaced at home but it can be done.
You will need to take the garmin apart, identify the battery, order a replacement and install it on the place of the old lithium ion battery.
this will void your warranty, best solution is to contact garmin and get it done with warranty. do at your own risk.
You can check this link for the battery
http://www.asianproducts.com/product_6/Li-ion-750mAh_P11689267506907246.htm
standard CR2032 ,this u can find any radioshack shop..
CR2032 is Not Correct. Totally different form factor.
The battery can be replaced, you can buy it at your Garmin dealer or on the Garmin Website
...also not true. The Garmin web site Li-Ion batteries are not for the 305, and look to me to be the wrong dimensions. They are listed as for the Nuviphone or some such.
go HERE
for battery replacement better to contact Garmin dealer.
it could cost $85.00 to replace the battery and do maintenance checks on it.
GArmin 305
Hello ! how can i change Batterie in garmin 305. You've got same problem. Thanks Velioglu
my garmin 305 don´t turn on
Garmin Forerunner 305 won't turn on and...
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
broken screen-garmin forerunner 305
How do i get this fixed
t wont even charge up and it won't switch on...
My garmin 305 has died, it flashes onto the screen then dies, I have tried charging it but nothing works, not even...
when Im running it seems that it will only mark...
when Im running it seems that it will only mark my first 2 waypoints and when I stop after im finishing my run...
forefunner 305 distance and course maps not...
I have tried everything to get my distance working. As soon as I downloaded the updates my forerunner has been out of...
garmin 305 interval training
When pressing enter after setting up for intervals an alarm sounds which will not stop. you cannot operate any of the...
Fix-O-Meter
2,013
2,013 people viewed this problem
- 0 people are following this problem. Be the first!
Top Garmin GPS Device Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
