Question about Jenn-Air JMC8130DDS Microwave Oven
How do I replace light bulb (lamp) for JMC8130DDS?
The Jenn-Air microwave model JMC8130DDS light bulb needs to be replaced but I don't know how to get to it.
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: JENN AIR MICROWAVE FUSE (JENN AIR MODEL M167)
The fuse holder may be loose.
With the microwave unplugged, if you can easily turn the fuse with your thumb & forefinger while it's in the holder, it has overheated and fatigued and should be replaced.
Simply squeezing its terminals together with pliers is not really a good solution.
When a connection is loose, heat results, which eventually melts the fuse internally.
This is usually evidenced by a very tiny ball of solder at the point where the end cap meets the body of the fuse.
You can use a generic holder - it's a lot cheaper than ordering one. The connectors should be 1/4" tabs and it should be rated at 20 amps or better.
You should be able to get one from a home center or local appliance parts store.
If it's not loose, then it may be a failing magnetron or high voltage transformer pulling too much current.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
SOURCE: Jenn-Air Microwave - no power
Had the same problem. Removed the unit (snapping off the upper and lower trim rings was a chore but they do snap off) and tested the power. Plug behind the unit was good. Pulled the cover and checked the thermal fuse with ohm meter. No good. Replaced fuse, microwave would run for a second, then light goes dim and it buzzes, then it blew the fuse. Per above suspected Capacitor. Changed that, and we are back up and running. Thanks!!
Posted on Sep 27, 2008
freetek
  • 5568 Answers
SOURCE: jenn-air microwave dead
I'm afraid since Jenn Air has become a division of Whirlpool (along with numerous others) the quality has suffered.
I was going to suggest that you purchase a service manual for your unit so you could 'reset' it yourself. Service manuals can cost from $12-$40 US and in many cases obviate the need for 'professional' service calls. However, I couldn't find one offered for your model number so your only choices are to continue to pay for 'service' or examine the guts visually to see if you can locate any reset feature. This is what I would do.
When microwaves fail, older ones generally need a diode, a big capacitor or the magnetron replaced. Newer units are suffering power supply failures as many have moved from the reliable but less efficient 'linear' power supplies to 'switched mode' types that are more efficient but more complex and prone to failure. These later types usually have the word 'inverter' in the model description.
Posted on Jan 04, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: how do i remove a built-in jenn-air microwave?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If not, try here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the fuse is good, it may be the magnetron thermal cutout (TCO or thermostat) or the oven cavity thermal cutout (TCO or thermostat).
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
Manual for jenn air microwave jmc8130dds
Like most manufacturers these days, Jenn-Air offers manuals online. I did not see specific instructions for removing the panel, but here is a link to the parts diagram which may offer some hints. You can also call or chat online with Jenn-Air Customer Care.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JMC8130DDS.pdf
Jan 01, 2015 | Jenn-Air JMC8130DDS Microwave Oven
My Jenn Air microwave model JMC8130DDS door panel has come unglued...what do I use to reattach it?
Super glue, hot glue, or J. B. Weld would all work, if applied neatly in minimal quantities to squeaky clean, dry surfaces which are then clamp lightly until the glue sets.
Jan 05, 2014 | Microwave Ovens
JMC8130DDS power level does not change
The owner's manual is free here.
Let me know if you still have trouble.
Oct 27, 2013 | Jenn-Air JMC8130DDS Microwave Oven
NEED OWNER'S MANUAL IN ENGLISH, PLEASE
go online look up your microwave by name then model for the manural then print it
Sep 28, 2012 | Jenn-Air JMC8130DDS Microwave Oven
Jmc8130dds microwave died. any thoughts. previously numerous messages about locking the screen on its own.
I think it is time to replace the microwave oven, the fuse has blown and there are numerous reasons why, shorted power transformer, shorted filament winding in the magnetron, cracked high voltage diode with a high level short, and a shorted high voltage capacitor, not to mention issues with the keypad and microprocessor control board.
Mar 20, 2012 | Jenn-Air JMC8130DDS Microwave Oven
Model JMC8130DDS won't heat up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [][
Aug 21, 2011 | Jenn-Air JMC8130DDS Microwave Oven
Is there a secret way to access the light bulb in my jmc8130dds???
Hello, Thank You for using FixYa. I will be helping you today. I belive you have to remove the unit and remove the top to access the light.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Jenn-Air JMC8130DDS Microwave Oven
Replace the fuse. Need a drawing or something to tell me how to get to the fuse. Cannot see how to do it easily, without removing it from the wall.
The fuse for this model is on the filter board on top of the internal cooling fan frame.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven (JMC8130DDS) here.
If the fuse tests good, then the oven cavity thermostat, magnetron thermostat, and control circuit board (which we repair) are other parts that can make the oven dead.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Jenn-Air owner's manuals and installation instructions here.
Jan 01, 2011 | Jenn-Air JMC8130DDS Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC8130DDS Microwave Oven Logo
90 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
