Question about Nintendo DS Console
Ds stylusthinks its pointing at another area of the screen
My ds stylus goes on a different area of where i point it.
say in the game phantom hourglass you need to mark something on your i map i place it somewhere but the mark goes to a different place. now im stuck in a room because my stylus does this
  • 24 Answers
Calibrate the touch screen ....start your ds with no game in it and click on the small ds at the bottom of the screen,next ,touch the yellowbox on the right and follow the calibration instructions.......if you cant get it to work then change the touch screen......good luck
Posted on Feb 28, 2009
Web setup
With a Wi-Fi compatible game inserted into your Nintendo DS, access the Nintendo Wi-Fi Connection Settings screen. Your game manual provides information on how to do this for the game you are playing.
  1. Tap Nintendo Wi-Fi Connection Settings
  2. Tap one of the Connection slots
  3. Tap "Search For An Access Point"
The Nintendo DS will then display the name of your wireless access point.
If your Access Point has a blue, unlocked icon, tap the Access Point name, and then 'OK.' The Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a red, locked icon, the Nintendo DS has detected WEP key security on your router. Tap the Access Point name on the Nintendo DS and then enter the WEP key for your router on the following screen and tap 'OK' to save the settings.
Tap 'OK' again and the Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a gray, locked icon, the Nintendo DS has determined your router's security settings are not supported by the Nintendo DS. In order to connect to the Nintendo Wi-Fi Connection, you will need to either switch to WEP security, or remove the security setting of your router when connecting with the Nintendo DS.
NOTE: All information taken from
Oct 09, 2010 | Nintendo DS Lite
Touch screen off-centre
When you load up the DS without a game card, there is an option that is a system calibration that requires you to touch teh screen in certain points, that will realign the screen. This should help! Hint.. Use the stylus to do this, not your finger! :)
Oct 26, 2009 | Nintendo DS Lite Console
Screen does not react to the stylus when touching on found object
You could try calibrating the screen. To do this, you must go to the little DS in the center of the screen when you turn the DS on. Then touch the yellow square on the far right. It should give you instructions from that point on. Make sure that your stylus doesn't have a scratch on it! If it has a little nick down the middle, then your screen might not get a clear reading as to what you touched.
Hope it helps~
May 03, 2009 | Nintendo Mystery Case Files: MillionHeir...
I cant touch two points at once on my ds touchscreen!??
nothing is wrong with your system and there is no setting to change. the ds is programmed to find a common point between two signals of contact. try using to find a solution to the puzzle. this is not however, as system or setting problem.
Mar 19, 2009 | Nintendo DS Console
The screen freezes just after it says hello
have you used the stylus to touch the screen around the Village to start the game? which part are you **** on exactly?
Jan 07, 2009 | Nintendo Professor Layton & the Curious...
None responsive DS lite screen
It sounds like you need a replacement touch screen. They are reasonably simple to replace if you're confident with taking it apart, otherwise you'll need to pay for a repair. You can buy touchscreen on ebay fairly cheaply.
Jan 05, 2009 | Nintendo DS Lite Console
How do you start the lawn mower on imagine babyz nintendo ds?
Put the stylus on the red ring and make short quick strokes to the right. With each stroke you will see the cord pull out and the ring will turn green. I did this about 30 times, then finally i used my finger instead of the stylus and is started up on the third try.
Dec 22, 2008 | Nintendo DS Lite Console
Bellum fight drawing the hourglass
It needs to be figure 8 you draw, don't draw it back wards (lot's of us do!) so try starting at a different point. Also it does not have to be huge - just think of writing the number 8 as answer to a math question on the DS. Just keep trying different ways, I sometimes had this problem with the Frog symbols, it's just a matter of triggering the right spots in the touchscreen.
Your game is not faulty.
Nov 17, 2008 | Nintendo The Legend of Zelda: Phantom...
Nintendo DS Console Logo
107 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
