Question about Kohler 1107-R-0 ProFlex Bath Tub with Flange and Right Hand Drain Finish: W
Kohler bathtub spa does not work at all
Just moved in a house and the bathtub spa does not work at all. It has a button connected to an air line for a on and off switch. have tried water at different levels still nothing. Can not get to pump very easy. The bath spa has a air pressure switch that does pump air into the tube. The tube is clean. There is electrical power to the pump motor. The access panel is removed. There is no visible corrosion around the pump motor. When the air switch is depressed, the pump motor remains idle. All water tubing is intact, no leaks.
The incoming wiring attaches to a sealed end of a typical elec. junction box (metal). The air tube is attached at the opposite end (also sealed). The box is mounted on top of the pump motor. The power to the motor goes downward into the pump. I have very limited access to the pump and the top elec. box. The plate on top of the box has rust. If I can remove it, I have no idea where to continue trouble shooting. I do not know the date/manufacturer of the pump. There is an impeller attacment on the motor with a mounted hose connection. I bought this house 14 years ago. The spa tub unit was in the bathroom. It could have (?) been installed in 1990. What do I need to do other than an expensive technician service bill??
  • Anonymous Mar 20, 2009
    I have a similar problem, the air switch in the motor is bad, can I pull off only the end of the motor to replace the air switch?
  • 125 Answers
If the air tube is still connected to the air button on the side of the tub and you are pushing it with no results then either the motor is no good, the air button is no good or the air switch in the box is no good.
process of elimination, start with the pump. take the switch off the motor or out of the box and make sure you can get the motor to come on. If the motor comes on then move to the air switch and hook it back up and see if you can blow into the air switch with a new air button or a straw and see if the switch will activate the pump. if it does then you most likely have a bad air button ($12). If you cannot get it to activate the pump then the air switch is bad ($21).
Posted on Feb 24, 2009
  • a_bartolotta Sep 04, 2010
    I have a similar problem, I hear the motor bzzzz for like 5 seconds then shuts off, guessing I need a new motor. The house is about 2 1/2 yrs old, and we use the whirlpool like once or twice a month.
  • US Parts Center
    US Parts Center Sep 06, 2010
    sounds like a new motor is in need. when a motor doesn't start all the way up it means there is a serious problem.
    You will need the model number and brand of the pump in order to match it up with the correct replacement.
My airflow valve is pouring water out on spa
Water coming out of the air controls is usually caused by the water jets being turned off or blocked making the water go backwards in the spa system.
Open the jet faces and make sure they are all open and not blocked.
Jan 10, 2015 | Kohler K-1110-AH-0 Purist whirlpool with...
Kohler led lighting and jacuzzi motor + jets stopped working but automatic line clearing air still blows when tub is emptied.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 06, 2013 | Kohler Home
How to fix my air whirlpool leaks
If the light fixture is leaking you will need to remove light housing and put a small bead of silicone around the face flange and reinstall it.
Rod
US Parts Center
Feb 06, 2013 | Kohler K-1457-AH-96 Portrait 5.5 whirlpool...
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
Jets in whirlpool tub not working
If its on a GFCI circuit reset switch.
Air button activation - check for loose air tube connections or bad air button.
Electronic control - contact a spa technician for diagnostics.
If the error is not electricity to the pump or the button(s) controlling the pump - it is likely a bad pump.
Jan 17, 2012 | Whirlpool Home
When you depress the air presure butoon on the kohler whirpool tub a clicking sound is heard but the motor does not run. There nis powewr to the receptacle that the pump/motor is connected to.
What you need is a new air switch for the back of the motor. The air tubing connects to it on the motor. that is probably what is clicking when you push the air button on the top of the tub. Once you change that air switch you will be back in HOT WATER !!
Should be a TBS-310 or TBS-301 latching air switch is the one you need. Either of those models will work in a Kohler pump.
Feb 04, 2011 | Home
Where to buy a Kohler air switch and air button?
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Jan 04, 2010 | Kohler 1107-R-0 ProFlex Bath Tub with...
Motor not working at all. Won't even go on
a good electrican will check for power but may not be able to test a printed control board. Maybe simpler to get a spa repairman
Aug 12, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
Mar 04, 2009 | Home
you need to see if there is power to the pump 1st, there may be a switch somewhere thats not been switched on or it may have tripped out so check that. the air pressure switch maybe faulty or the plastic hose may have even come away from the switch.think of the basics 1st then look deeper, if you have power at the pump then it can only be the switch or worse case scenario a new pump.
you might have to remove the bath panel to gain access to the pump better?
kindly
Richie
Dec 14, 2008 | Kohler 1107-R-0 ProFlex Bath Tub with...
Kohler 1107-R-0 ProFlex Bath Tub with Flange and Right Hand Drain Finish: W Logo
1,752 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
