Question about Canon PowerShot A75 Digital Camera
Wont take picture
When I push the shutter button....I hear a little clicking and whirring inside the cam but it wont take a picture.  Everything else works...zoom..settup etc....
jackboy
  • 2985 Answers
SOURCE: Shutter release button is stuck
You have two choices 1. take it to a repair shop and get a quote[almost the price of a new camera I wager] 2. Try your self[bearing in mind that if you cant fix it you'll have to buy a new camera] Chances are the in dropping it the button has forced it self through an aperture in the casing so that it cannot return. If you have access to fine screw drivers[Jewellers/watchmakers]slack off the screws holding the case together- done take 'em right out just slack 'em-it might pop right back out- if it does tighten up.
Posted on May 07, 2007
SOURCE: Canon IXUS 500 It will not take a picture the
Try to see If you can see a photo in Playback mode from your memory card (Transfer a good photo to the card first) Do all the menus display correctly? If so it would seem the camera sensor (ccd) is bad. Canon had a recall on these models with bad sensors and will repair them free of charge.
Posted on May 14, 2009
SOURCE: with a canon 1000d, shutter button wont work, have
try to disable the mirror lockup at C.fn no. 8
Posted on Dec 12, 2010
jacko0
  • 159 Answers
SOURCE: camera turns on fine, when press shutter button to
try this:
http://jacko0.wordpress.com/2009/10/13/d40x-underside/
Posted on Jan 23, 2011
ZJLimited
  • 17970 Answers
SOURCE: Fuji Xp camera says "Zoom
The lens error indicates that the movement is inhibited possibly by sand or grit. It also may be misaligned or an internal component has failed. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
Try turning the camera with the lens facing down and shake to dislodge anything stuck and try removing batteries and memory card. There are a number of things you can try:
- Ensure batteries are fully charged
- Look carefully between the lens and the camera body for any sand or other dirt etc
- Try turning the camera with the lens facing down and shake to dislodge anything stuck
- Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
a. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
b. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
c. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera.
Additionally, here are a few links to some other things to try. With newer cameras I am usually hesitant to suggest these options since they include some more extreme procedures that may cause further damage if not done correctly, but since yours is probably no longer under warranty, they may save you an expensive repair bill. An older Canon camera is used to demonstrate these procedures but, the lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time. Click on or copy and paste the links into your browser.
Lens Covers
* Lens FIX 1
* Lens FIX 2
If the "do it yourself" approach doesn't work out for you and you need conventional repair you can get an online estimate at the link and please see the note below: unitedcamera.com/FUJI-FINEPIX-E550 (sample)
Hope helps.
Posted on Sep 21, 2011
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
When I try to take a picture you hear a clicking noise and the flash is working but it will not take a picture
You may be too close to your subject and the autofocus is not locking in. back up a few inches and the shutter should go off. Try turning off auto-focus.
If this isn't the case it could be a shutter problem. Turn off the flash (if you don't you'll get blinded during my next step) look inside the barrel of the lens and click the shutter...you should see a little flicker inside the lens as you hit the shutter button. If you do see it, then it is in fact just the shutter...if not it's the camera itself. Be sure you are holding the shutter button down completely...as halfway only allows you o focus.
Nov 28, 2010 | Nikon D40x Digital Camera
My 1997 plymouth neon wont start
Please explain your problem a little better.Do you hear a click click when you turn the key?Do you hear a whir whir as in the starter is turning over but doesn't want to start?Thanks,Greg
Aug 24, 2010 | 1997 Plymouth Neon
When I hook up my Little Shots Camera it says can not connect to device
Uninstall all old pc cam,mars software and do a fresh installation. Restart computer.Before plugging in usb cable,push the shutter button down and hold it.Shutter is the button that takes the pictures. Now plug in usb cable. Camera should say pc cam and installation of software should start and complete. If asked about newer reference files answer yes. Software should now be installed. To use as pc cam,Dbl Click pc cam,mars icon on the desktop.New screen will appear.click on right facing triangle and another screen will open. Camera will now show on monitor what it is aimed at.To shut off,close all screens,and click on icon tray and shut usb device if necessary. To use as camera and view pictures,connect usb cable without pushing any buttons,and camera will say usb,Dbl click my computer,dbl click removable disk D,E F whichever it has been assigned,dbl click DCIM folder,and there are your pics to do waht you want with,save,print etc.Do not delete pics using the computer,delete only by camera so you do not damage files necessary to store and take pictures.If you do camera may have to be reformatted.Disconnect from pc same way by clicking usb icon in tray and stopping device,then its safe to unplug cable.
Dec 26, 2008 | Blue Microphones Blue Hat Little Shots...
Sony's broken button issue
You need to use you fingernail and pop off the entire button assembly. When you have done this you will be looking inside your camera.
Set the new button assembly into the slots. It will not want to go on by just pushing down. The plasitc assembly is very slick so put a small piece of scotch tape the yellow stuff. I put the tape around the plastic assembly. Make sure you are only putting tape on the chrome plastic assembly. The reason for the tape is to get a good hold of the plastic asembly.
Once you have the tape on the assembly/chrome piece you need to really push down and twist clockwise. You will hear a click and then another click. Make sure you hear two clicks. I had to push and twist pretty hard to make it lock into place.
Jun 07, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Polaroid Problems
If your having problems with your camera, for about 20.00 you can buy the same camera on Ebay.
Mar 05, 2008 | Polaroid OneStep AutoFocus Instant Camera
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
Mar 01, 2008 | Nikon D100 Digital Camera
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Feb 17, 2008 | Nikon F80 35mm SLR Camera
My camera wont click (take pictures)
try replacing the batteries with new ones, and if it persists you should contact casio customer support. hopefully you're still within the warranty period, because they will over charge even on minor repairs(they all do). there is a problem with the shutter mechanism, either electronic in nature, or mechanical. the click you're hoping to hear is the shutter release, and its not releasing. give them a call, get a repair estimate, and if its too high try finding a repair person with good hands that wants to have a go at it. nothing but good luck ;]
Apr 09, 2006 | Casio Exilim EX-Z50 Digital Camera
Canon PowerShot A75 Digital Camera Logo
1,406 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
