Question about Protron PLTV-32 Television
Red light does not come on showing that the poweris on.
Had a storm and tv went off and hasn't worked since.cord good with continuity.
  • 44 Answers
Hi!
Giving the scenario of a storm with a likely power surge, any of the internal boards could have been damage!! This would require a professional to go through completely!! Not an easy fix!
Posted on Feb 19, 2009
TV Will not power on
HAVE YOU CHECKED PLUG AND INTERNAL FUSES
May 28, 2015 | Televison & Video
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
Why does my TV turn on and off by itself continuously when plugged in? (The remote is not being activated)
Hello, there are several things that it could be, but if the set comes on with a picture even for a couple of seconds, I would bet it's the main board failing. Part # is EBT48854401.....thanks
Apr 24, 2017 | LG 50PG20 50 in. Plasma HDTV
We were watching tv, and it was a storm. My lights went out and the tv turn off, when we turned it on again it wouldn't show picture but you could hear sound. We waited a couple of months to actually...
what caused the inital problem was a surge of energy caused by the storm. the exact problem, i don't know but it may just be that some of the power cord(including the power cord wires on the of the TV) wires have blown
Mar 05, 2011 | RCA M50WH185 Television
Blackberry storm wont turn on
it sounds like *********** Borad - or The Circuit Borad on the Phone might be damaged.
Did you drop it?
Mar 31, 2010 | RIM BlackBerry Storm 9530 Smartphone
When powered on, automatically shuts off with red flashing light.
you can claim the repair on your home insurance policy as FUSION
Sep 13, 2009 | JVC AV-27920 27" TV
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking red led light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
May 19, 2009 | Philips 34PW9846 34" TV
Dead after storm
yes, take the back off, and follow the power cord. You will see a fuse in the board.You have the same problem as I have. I replaced my fuse, and plugged it back in, It made a sizzling sound and blew the fuse again.Maybe you will have better luck, with your set good luck rob
Sep 17, 2008 | RCA F36665 36" TV
Protron PLTV-32 Television Logo
32 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
