Question about Sony PlayStation® 3 (60 GB) Console
Blinking lights list of faults
Does anyone know if, when the PS3 is in fault, the light bliink for specific errors? If so does anyone have a list of the error codes associated with the specific series of blinks?
  • Anonymous Mar 02, 2009
    my cosole seems to be totaly bricked but everytime i turn it on it turns it's self back off with a different sequence of lights. just flashing red. yellow then flashing red and yellow, green then flashing red.
  • Alex Keen May 11, 2010
    No it dont im affraid it just means theres an error,
    can you please tell me what it is affecting
    President:
  • 2,653 Answers
Not really. There is just the blinking red lights: usually power issue or motherboard issue.
And the YLOD, usually releated to a video chip problem but it's always a hardware defect which causes that one.
Posted on Feb 20, 2009
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Standby light blinking 7 times KDL60EX700 model number
Have you replaced the lamp?? The lamp may need to be replaced. Hope this helps.
May 25, 2011 | Sony KDL60EX700 60 in. TV
Plasma tv th-42pd50u not come on and keep blinking red light two times and then stop again blinking red light two times and then stop not come on
The light blinking twice means there is a fault within the system and it is a code to tell Panasonic where roughly the fault lies.
Go to Panasonic's web site and look for your set then input the fault code and hopefully they will tell you where the fault lies.
Oct 16, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do...
Although you say it can't be overheated, it is possible it is a result of overheating. When you get this error it means a general hardware fault. However, the most common fault found is when either the CPU or GPU processors become so hot that the solder devlopes microscopic cracks that do not close when it cools. This means that there is not a good electrical contact and the PS3 fails. So your PS3 may have been working fine the day before but when you turned it off it would of been hot inside. The circuit board and components would of cooled down essentially making the solder joints contract and open up the cracks in them.
There are guides out there to repair YLOD (yellow light of death) which explain step by step how to fix it. Unfortunately it is not a permanent fix and your console could only last hours after doing it.
Usually you will need a replacement PS3. If it is still under warranty give Sony a call who will replace it free of charge.
Hope this helps and thank you for using FixYa
Sep 04, 2010 | Sony Playstation 3 (PS3) Console
Sony kp tv stand by light keeps blinking and no picture
The standby light LED BLINK is in specific numbers, please count that how many time LED BLINKS in specific time and in specific numbers like 1 time 2 time 3 times etc, every blink has its area of fault which processing IC detects, Therefore please count and let me know the number of blinking stand by light and then i can tell you the area of fault and its solution.
Hope you will understand my sayings, if need more clarification write in comments.
thanks for using fixya.
Jul 25, 2009 | Televison & Video
Light blinking on D4my 1993 accord has the Drive4 indicator light blinking and since that has started the car will not down shift automatically. Anyone know what all this could mean?
the light blinking is an indication that a fault has occured in the automatic transmission, u will need to have Honda test the system for a fault code to determine the exact problem
Jun 25, 2009 | 1993 Honda Accord
Red blinking light on ps3
u have a 60G ps3 i had the same problem it's a design fault phone sony and they will replace with new ps3 mine comes 2morrow
Dec 29, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
