Question about Philips Magnavox 27MS343S 27" TV
How do I shut off the Closed Caption feature?
How do I shut off closed captioning? I have hit the "cc" button on the remote and it will take it out temporarily but when I turn on the tv the next time, I have closed captioning again. And of course, I can't find the manual. I was hoping it was online. This is a Magnovox Smart Series tv - approx. 13 or 15 inch screen. A great little tv though I don't know how it will be after the conversion.
Bluffy you should access the menue on your remote and be able to shut it off!
Posted on Feb 16, 2009
How do you shut off the closed caption n
It might be the Subtitle feature not CC(close caption) that you are viewing. The following is the procedure for a Samsung player. Other players would follow a similar procedure.
1. Press the MENU button on your remote control.
2. Use the navigation buttons to highlight System.
3. Highlight Accessibility.
4. Press the right navigation button again to access the Accessibility options, highlight Subtitle and then press the ENTER button.
5. Press the ENTER button again, highlight Off and then press the ENTER button once again.
Hope this helps.
Mar 23, 2016 | Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
Shutting closed captioning off with out a romote for the tv
Is there a "CC" button on the remote control of your TV. If is, press it once. If not, enter into int Menu option to select the closed caption ON/OFF window, and make the closed caption function to OFF.
Jun 04, 2012 | Televison & Video
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
How do you shut off the closed caption feature?
I do not know this dvd player, but on most anything with closed caption, you hit the cc button on the remote until you come to '0' or 'off'. As CC has about 6 channels it can use, but really only channel '1' is used. So you might have to cycle through the CC channels until closed caption disappears. Hope this helps. You might also have a setup menu on this DVD where you can control the CC.
Just cycle though it till you get to '0' or off, exit the setup menu.
Jan 07, 2011 | KLH DVD-221 DVD Player
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
How do I turn off spanish closed caption?
the close caption feature is different than the language in the menu.
Try to find the close caption feature in the menu and get it off. Now if she hit a button then chances are you find some button with that description in the remote control (close caption or text) make sure is off.
Apr 08, 2009 | Sharp 27K-S100 TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Philips Magnavox 27MS343S 27" TV Logo
512 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
