Question about LG WM2277H Stainless Steel Front Load Washer
Front load washer leak
LG Tromm WM2277HS; water leaks out from bottom of front loading door
Could this be the rubber seal on door??
    President:
  • 1,902 Answers
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Why is my LG front loader leaking from bottom front of washer?
When cleaning the filter you may have dislodged the o-ring seal on the filter unit. Check the condition of the seal or if missing replace it with a new one.
Sep 13, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Aug 19, 2009 | LG WM2688H Front Load Washer
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Jul 25, 2008 | LG WM-2277HW Front Load Washer
LG WM2277H Stainless Steel Front Load Washer Logo
926 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
