Question about Neoware EON 3000i (ba-eon3000i) Network Terminal
How do I reset an unknown password for a Neo-EON 3000i
I can get up to the point of pressing F2 at the connection manager screen and I do not have a password to continue. Any help getting past this so I can do a factory restore would be appreciated.
Steve
How can i find my bios? i need to fix it because the blue screen is saying bios memory or cauche or shadowing things
Try powering off the machine then turning it back on. When it comes back on, immediately press the key to access your BIOS settings (it should be on the startup screen, if not try the F2, DEL, or ESC buttons)
Oct 03, 2016 | Neo M74S
Factory reset forgot screen lock
sony ericsson xperia neo v mt11i need factry reset forgot screen lock
May 20, 2013 | Sony Ericsson Xperia Neo V MT11i
How do i recover toshiba tecra 730xcdt windows password?
If a user account needs to be reset, logon as the administrator or as a user with administrative access, and then follow these steps:
Click Start, point to Programs, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
Expand the Local Users And Groups object under System Tools, and then click the Users folder.
In the right pane, right-click the appropriate user object, and then click Set Password.
Type the appropriate password, and then click OK.
Click OK to acknowledge that the password change succeeded.
Close the Computer Management console and Administrative Tools windows.
The user can log on with the new password.
To Reset the Administrator's Password
Log on to the computer as a user with administrative privileges, and perform the steps
listed above for the Administrator account.
If the Administrator password needs to be reset, and there are no other users with administrative access, there is no way to recover the password and the operating system will need to be reinstalled.
or if you have not set a bios password
restart your computer you will see on your screen to press a certain key to enter bios usually the Delete or the F2 key
press and hold that key to enter set up BIOS where you can set or remove your password
this will differ depending on you computer and bios
hope this helps
Aug 08, 2012 | Toshiba Tecra 730XCDT Laptop AC Power...
Reset log on password
hope this helps
Aug 03, 2012 | Dell OPTIPLEX GX60 Motherboard
Need to delete unknown password how do i do this ?
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Jan 04, 2010 | NorStar M7310 Corded Phone
My test light comes on every 5 minutes or so and disconnects me from the internet. it just started doing this yesterday. it is hooked up correctly but i will be on the internet then a no connectivity box...
Hi ,
This is Neo . Thanks for contacting us .
Reset your Netgear and Try it again .
The steps to be followed are ,
STEP 1
Reset the Router by pressing the RESET button on the rear till the Test Light blinks.This takes about 10 seconds . Use a pen or paper clip to access it .
Release the button and wait for the Router to Reboot.
STEP 2
Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
STEP 3
If the Router was not cleared after rebooting, unplug the Router's power . Then Press and hold the Reset button.
STEP 4
While the button is held down, reconnect the Router's power . Continue to hold the Reset button for 20 seconds after reconnecting the power . Wait for the router to reboot .
Then Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
Do the setup and try to connect to internet .
The Router will work .
Thanks & Regards
Neo
Thanks for using FixYa.com.
Dec 21, 2009 | NetGear WGT624 Wireless Router
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
Oct 13, 2009 | RCA 25450 4-Line Extended Range Multi...
Need to reset password for verifone omni 3740
If you press the F2 and F4 buttons and enter 1 Alpha Alpha 66831 and the terminal goes back to the idle screen then the system password has been changed or the battery is bad in the unit and will have to be replaced. Either way it will have to go to a repair facility to be corrected.
Aug 12, 2009 | VeriFone Omni 3700
Acer extensa 5220. how ;open bios? f2 or f10 or f12 or what?
Try On bootup you should either Press 'DEL' or 'F1' or 'F2' to enter the BIOS
Jun 14, 2009 | Computers & Internet
Neoware unit has a password but nobody knows what it is...
NeoLinux Password Reset
1) Restart the NeoLinux appliance.
2) On power on hold down the Shift key.
3) From the LILO Boot Menu type vga single and press Enter.
4) When you see "Starting up...open: No such device" press Alt/F2.
5) From bash# type passwd and press Enter.
6) Enter the new appliance password and press Enter.
7) Retype the new password and press Enter.
8) Type /sbin/reboot and press Enter.
Dec 17, 2008 | Neoware EON E100 64/128MB NEOLINUX...
Neoware EON 3000i (ba-eon3000i) Network Terminal Logo
215 people viewed this question
Top Neoware Computers & Internet Experts
David Payne
David Payne
Are you a Neoware Computer and Internet Expert? Answer questions, earn points and help others
