Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Dishwasher flooded,I have cleaned filter.
When I try to switch it on it makes a noise but does not appear to be working?
    President:
  • 1,902 Answers
Check your pump and make sure that it is not only pumping water in but is also pumping out. These motor have two directions and sometimes will only work in one direction and not the other and this is a major problem. You will need to replace the pump. You can order parts at repairclinic.com
Posted on Feb 16, 2009
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
Whirlpool DU915PWSSO dishwasher. When door is closed lights work. I can push start and select options, but nothing happens. No noise, no water, nothing. Pushing Cancel/Drain does appear to make the...
try pulling off the bottom spray arm under that plastic cowel is the filter system clean it out . take the cowel off and its very easy to clean the filter if that doesnt work then underneath the dishwasher where the water inlet is there is a valve . it has two outlets one going to the dishwaser and one coming from your water supply . check to make sure u have continuity going thru the valve if its not working replace the valve (word of caution turn off the water when replacing valve ) Also before changing the valve pull off both hoses from the valve there is a filter in each inlet make sure they r clear and not plugged
Oct 03, 2013 | Dishwashers
Flood switch activated on dishwasher DW60CSWI
Please clarify the model number. i am assuming you have a standard height single door dishwasher. It is likely the flood switch assembly itself is faulty and giving false results. Check the base of the dishwasher - item 95 in on page 10 in this manual. The microswitch could be faulty or the spring might be stuck.
Jan 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Flood switch activated on haier dishwasher.
Check an clean filters first.
Check over flow pan if its that make sure you have towels down to catch the water.
Hope it helps
Dec 20, 2012 | Dishwashers
I have a fisher paykel soft touch dishwasher about 10 years old. The F1 message came on and we have taken out the inside filters and cleaned enitirely., Was working fine until it came on by itself during...
The flood sensor is located below the bottom drawer. If you take the bottom drawer out and there is water in the pan then the flood switch is probably tripped. Soak up the water with a towel and apply a hair dryer towards the rear left corner of the cabinet. The flood switch is part of the Mains Filter control board and should not be messed with (even with the dishwasher unplugged)... There is an underlying problem that caused the F1 fault and you should have a technician look at it.
Jun 17, 2009 | Fisher and Paykel 24 in. DS603H I Built-In...
Error message F on shu 6800
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore Elite - Flooded bottom
this is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Nov 19, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
75 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
