Question about Logitech EX100 967499-0403 Keyboard
Keys have switched function
The @ key has switched to the " how do you change it back ??
  • 385 Answers
Try pressing ALT GR + 2 and you should get the @ key
Thanks,
Lolita
Posted on Feb 16, 2009
For UK keyboards, the shift2 key is " whereas USA keyboards shift2 is @. you probably just need to change it under the language bar.
Posted on Mar 27, 2009
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
I have a Compaq Presario CQ56-204CA. The default F keys are functions like brightness and stuff. To reach a F key, i must hold the Fn key. I would like to switch that to the default keys is the F keys....
You can't. Generally speaking, the special "F"unction key PC laptops have cannot be modified by the user. They are this way by design, because the normal F1-F12 keys have very different functions than the "F" keys (in Windows and in any highlighted program/windows in a given moment) and you can't possibly change this, ehm, "tradition" of the Windows (or even DOS!) platform....
May 03, 2011 | Computers & Internet
I have had this netbook (asus: 1005H) for 8 months. Everything worked fine, but now the function keys won't respond? Anything I can do? Danny Doss
Within this link is the documentation for your laptop:
http://usa.asus.com/product.aspx?P_ID=Ues16Gw2OcqSjUNt
You might need to scroll down to find the English version, and then download it from one of the links.
It's possible that there's a function key turn on/off key (or sequence of keys) that might have been pressed. This turned off the functions keys so they're acting as different keys. If your function keys have multiple symbols on them, then they can act as different keys when in this different mode. You need to switch back to the 'function key' mode. Check out the documentation and see if there's something like this.
If this has helped please remember to give me the appropriate 'thumbs up' feedback. Thanks, and good luck!
Aug 27, 2010 | ASUS Eee PC 1000HE Netbook
I sometimes accidentally switch the keyboard to characters other than standard English. I don't even know how I do this. How do I switch back to the standard keyboard? If I switch the computer off, then...
There should be a sequence that you need to press to change it from one type of keyboard characters to another. Look for a key that has the symbol of a keyboard on it. Most likely this is the key that is causing you the problems. Typically you have to press the Function key that is near the space bar as well as the key with the symbol on it to change it from one character set to the other. Evey laptop keyboard is alittle different than the next when it comes to which keys are "functions keys", so you will have to examine your keyboard to find the correct key on you laptop.
Aug 05, 2010 | HP Compaq Presario CQ50-110US Laptop
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
V3i switch right and left soft keys
change feature icons & home keys
Change feature icons, soft key labels, and
smart key function in the home screen:
- > Settings > Personalize > Home Screen
> Home Keys
Oct 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How do I shift to the blue key functions on the keyboard
I've run into this a lot myself and personally find it annoying more than useful. While typing, your punctuation keys suddenly switch to their french functions. By defaul, Vista assigns a keyboard shortcut fo changing input languages.
This shortcut is ctrl+shift - a very easy combination to press by mistake. To solve this problem, just press crtl+shift until you're back to english. You can change this shortcut or disable it all together.
Open the control panel then click "change keyboards or other input methods" under "clock, language and region". In the window that pops up, click "change keyboards..." then select the "advanced key settings" tab. This is where you can edit and disable language related shortcuts. To change one, click on the profile and then click "change key sequence". Under "switch keyboard layout", select "unassigned" to disable that shortcut.
Oct 26, 2009 | HP Pavilion dv6000z Notebook
My keypad is crazy,presses keys itself,all func. hav changed.
ok!!! your phone needs some clean coz the your keypad is randomly cant press will right!!!! then there is something on the switch of your phone i think you press it hard thats why the switch is not functioning well!!! that is tjust the problem of your cellphone ok!!!!
May 20, 2009 | Nokia N72 Cellular Phone
How do I switch from the green keys to my regular keys?
it sounds like you have turned on either your language bar settings and sometimes switch to another language, there is a function key you are hitting causing the keys to lock on that setting
Apr 01, 2009 | Acer Aspire 5920-6335 Laptop
Toshiba Satellite A45-S250 non-numeric keys locked
Your keyboard logic chip is in need of therapy.
Replacement of keyboard warranted.
Now, I thought that it might be a redesignation of your language code, but that proved not to be the case.
Mar 29, 2009 | Toshiba Satellite A45-S250 Notebook
Logitech EX100 967499-0403 Keyboard Logo
251 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
