Question about Zenith B25A02Z TV
TV comes on then shuts off in about 20 seconds
Something must be heating up and then it shuts off with a POP that comes through the speakers. What is the most likely component that would cause that? Zenith SM3247RK8 built in 1994. Sound works fine.
  • maccoak Feb 16, 2009
    After further diagnosis, with the TV on channel 03 and the digital converter box on and on a working channel I can get sound but the screen stays black for the 20 seconds then the whole TV shuts off with a loud POP through the speakers. It makes no difference what level the sound is set on , the POP remains at the same loud level. There are no visible indications of overheating on the circuit boards or any of the components. MACCOAK
    Problem Solver:
  • 7 Answers
Can't say for certain being a layman and the only reference I have is a little prior experience with a similar problem. So use this advice at your own risk. hold down your menu button, if set still goes off turn on again! press menu go to antennae not cable if it stays on at this point exit out of the menu then press and hold again and when it goes to display the channel your on press the adjust and channel up buttons at same time to get to the factory set-up screen once there use the select button to scroll through its lists until you find something like AFC automatic frequency control and set that to 7 by using the select button should you see AC while scrolling check if its on 1 or 0 it should be on 1 this may also aide you in solving the problem should this not help just unplug your set for 4 hours and plug back up that should hard reset the set.
Posted on Mar 26, 2009
Unit just shuts down, wait a bit, then works again, repeat process.
These units come with a Thermal Overload Protection device. It is not a timer, but when the temp. gets higher than normal, it shuts down to prevent damage to the motor. If the brush is dragging (full force) on the floor it will slow down the operation and heat up the motor. If the shaft has collected twine, rope, string, etc. it can slow down also. Clean the underside after each use.
Feb 27, 2014 | Tennant 90073749 BR-2000-DC High Speed...
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
Alesis RA-100 amp is tinny
To test speakers get a 1.5 volt battery and put the (-)wire of the speaker to the negative end of the battery. Then take the + wire and for a split second touch the positive terminal of the battery. You should hear the speaker pop! Listen to each unit inside the speaker, any that don't pop are not working.
If you look inside the amp you may see that something has burnt up. Look carefully at whatever is on the heat sink.
Dec 09, 2009 | Audio Players & Recorders
The TV shut off, made a popping sound. The
Power board short and bad capacitor blown, capacitors usually pop because of shorted or open rectifiers and linear devices that warp inside. This happens due to excessive heat exposure from the current draw. Bad diodes and FET's are usually the root cause as to why capacitors bulge then eventually pop. This means the the x-y sustain boards are not getting their supply voltage resulting a no picture....
The red light flashes an error code for a technician to read, the tv is in protection mode to prevent further damage. Get it serviced at your local repair center or take it back if its under warranty.....
Nov 04, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Your tv is probably going into a "protection mode" this means something inside the set had failed. This is the tv's way of shutting down before more damage can occur. This could mean many different things that could have gone wrong with this unit. Your best bet is to call your local dealer and have them come out and look at it for you. Tearing apart tv's is very dangerous! Some sets have up to 30,000 volts on the anode! GOOD LUCK!
Aug 17, 2008 | Mitsubishi WS-65712 65" Rear Projection...
TV doesn't turn on
When the set is turned on, the computer senses that something is wrong and immediately shuts the set back off. The standby LED will then blink a code, a certain number of blinks, to indicate exactly why the set was shut down. It is possible that your audio output IC is shorted, as this would make a pop or strange noises in the speaker just before the set shuts down, which it does to protect your speakers from burning up. The set should be looked at by a qualified tech familiar with Sony TV's.
Aug 21, 2007 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Zenith B25A02Z TV Logo
66 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
