Question about Oreck (AIRCOM1WOI) Air Purifier
Need wiring diagram for oreck xl air purifier
After taking my oreck xl air purifier apart because the routine cleaning was not making the unit run the ground wire was disconnected inside the unit. I have tried to research a wiring diagram for this unit because I believe if the ground wire is reattached the unit should work fine. Can anyone help me figure out where it needs to be soldered back into place?
5 Suggested Answers
  • 5 Answers
SOURCE: Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Posted on Feb 22, 2008
jerryg50
  • 1640 Answers
SOURCE: fans not working
You should send the unit back! I think they give a very long warrenty if I remember right.
It sounds to me by your description, like the fan bearnings may have seized.
You could check to see if there is any obstruction to the fan, but I would doubt that since they are normaly protected from being able to have access to its blades.
Jerry G.
Posted on Apr 27, 2008
  • 389 Answers
SOURCE: is the oreck xl professicnal air purifier a safe unit
...and so you should be! Worried, I mean. And not just about this particular machine. Ozone is an atmospheric pollutant (good news up in the stratosphere - bad news down here where we breathe it) and primary irritant of mammalian airways. It is a powerful oxidizer of organic matter, so it kills bacteria (good news) and can adversely affect anything else organic that it comes into contact with - leather, rubber, and you (bad news).
Personally, writing as a qualified chemist and biologist, I would not want to be in the same house as an ozone generator, let alone be in the same room as one.
If you really feel the need to "purify" your air. Do it without generating a toxic impurity!
Posted on Mar 15, 2009
SOURCE: Oreck XL air purifier motor failure
My Orek was making such a bad noise that my wife was going to sell it at a garage sale, I'm glad she didn't. It takes about 20 minutes to fix. All you need is a phillips screw driver, can of compressed air (or air compressor) and a can of silicone spray.
Pull out the filters and turn the unit upside down. Using a phillips screw driver unscrew the 9 screws holding the bottom to the top. remove the bottom. Use care as to not damage the fan. The fan will stay attached to the motor , pull on it and use a good cleaner like 409, Simple Green or a similar product. Wash clean and dry. Next get out your air compressor and clean everywhere, see the silver bearing holders on the side of the motor? Get out your can of silicone spray and give a good squirt on both bearing (close to the shaft. also spin the motor with your hands. See the large thing attached to the shaft? Those are the windings. See the metal housing the winding spin close to? Spray the silicon in there, a good amount. Make sure you didn't get any silicone on the end of the motor shaft where the fan sits on. If you did get some nail polish remover or acetone and wipe clean a few times. Then reassemble.
My Orek was horribly noisy, now it's quiet. My wife says is beeter than new.....
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: Oreck Air Purifier. Need to take it apart to clean the collection
i just used a butter knife wrapped in a Clorox wipe... being careful not to have the metal show so that it will scrape. when the wipe comes out black, rotate the wipe so that it will be able to clean. I used 5 wipes rotating. I could not figure out how to open the thing either so this was my solution.
Posted on Oct 13, 2009
Replacement motor
Did you check out ebay? Google it.
Mar 02, 2016 | Oreck XL Professional Air Purifier
Need a wiring diagram for Oreck XL air purifier Air8SD
I would look at the board using a high powered magnifying glass to see if there was any signs of broken stubs of wires sticking out of any solder joints. Also look for solder joints that have no other possible routes, (dead ends) that do not have any other connections running from them. Like a resistor that has a copper path on one end and nothing running from the other end. Or it could be a ground wire if no other spot is found.
Aug 04, 2014 | Oreck Air Purifiers
I can not get the cover back on my oreck xl air purifier
How about making sure it's not on backwards... Hehe. It only goes one way. If it isn't going back on, you're doing it wrong. Mind the notches and line them up with the unit, logo facing forward of course.
Feb 13, 2013 | Oreck XL Professional Air Purifier
Where can I get replacement wires for an oreck truman cell? Seems silly to spend 200 dollars when the only thing wrong is four 29 cent wires does it not?
Here is a link to where you may can find what you need. You will need to have the correct model number (not just XL Tower Air Purifier) , to find your mode.
http://www.ereplacementparts.com/oreck-air-purifier-parts-c-130239_130321.html
Hope this helps you find the wiring you need. Thanks for choosing FixYa.
Sep 19, 2011 | Oreck XL® Tower Air Purifier
I need instruction on how to clean my Oreck XL.
Unplug the unit before cleaning. Wipe off the cabinet with a soft cloth and a mild non-abrasive cleanser.
To clean the electronic collector, loosen the front grill retainer screw then press in the lock and remove the grill. Pull out the collector by the tabs on the sides using both hands. Snap off the charcoal filter from the back of the collector. Then slide off the pre-filter. Spray the pre-filter and the collector with the Oreck Assail-a-Cell cleanser and then let stand for a few minutes before rinsing with water. Otherwise, soak the pre-filter and the collector in warm water (bathtub or sink) with mild dish detergent. Soak for 2-3 hours. Rinse well.
Then allow the parts to dry for completely before reassembling the air purifier. Air dry only.
Pictures to go with the Oreck XL Professional Air Purifier cleaning directions are in the manual. It is available here: http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf . See page 5.
I hope this helps.
Jul 06, 2011 | Oreck XL Professional Air Purifier
How to open and clean oreck xl air purifier
You can download teh manual at
Jul 08, 2010 | Oreck XL Professional Air Purifier
How to remove the air cell
  1. Turn off unit and unplug it
  2. Along the front edge there should be a thumbscrew, loosen until it is free
  3. Lift front cover from left edge
  4. Pull cell from unit
  5. remove screen from cell, it slides out from the top of the cell
  6. remove odor/ozone absorber, it is clipped into the back edge of the cell
You do not need to be afraid to set the unit on it's back or side, just make certain not to drop it.
May 23, 2010 | Oreck XL Professional Air Purifier
Feb 23, 2009 | Oreck XL® Air Purifier
Dec 03, 2007 | Oreck (AIRCOM1WOI) Air Purifier
Oreck (AIRCOM1WOI) Air Purifier Logo
295 people viewed this question
Top Oreck Air Purifiers Experts
Mike
Michael Youngman
Michael Youngman
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
