Question about Maytag Neptune MAH5500B Front Load Washer
Machine will start and then stop
I can turn on my machine and it will start the cycle for about 5 to 10 seconds and then shut off.. it keeps doing this over and over what to do
    Scholar:
  • 79 Answers
It sounds like the motor control board is shot. Inspect the MCB for burnt components or a blown 10 amp fuse. This board is located down by the floor on the right side. See www.neptunehelp.com for disassembly pictures.
If you have a blown 10 amp fuse or there are burnt components then the MCB will need to be replaced along with the motor as Maytag has redesigned them to be more reliable. The new part number is 12002039, which is a motor conversion kit. It takes about an hour to install.
Posted on Feb 18, 2009
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
My Simpson eziload 750 will not shut off the water during cycles when supposed to
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
Apr 22, 2016 | Simpson Washing Machines
My meile machine is stuck in the descaling mode
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
May 23, 2014 | Miele CVA4070 Coffee Maker
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
I own a kenmore top loading machine model number 110 10 amp 60 hertz 120 volts the machine gets power and runs but the big control knob that controls the diffrent cycles is running only about 20 seconds...
sounds like you should replace timer (big control) timer motor is part of timer. Is timer knob speeding thru cycle that fast or just start/stop.
110 is manufacturer code for whirlpool, number after decimal is model number. tech sheet avail inside console by unsnapping left and right console covers and removing hidden screw at front bottom corners, pull forward slightly then fold console back (hinged at rear top).
Apr 26, 2009 | Kenmore 22642 Top Load Washer
Hi, my machine starts for a few seconds then stops and pause button wont stop flashing, have tried turning off and on but same thig keeps happenig, please help x
if it is a HE kind of machine it is supposed to stop and start a bunch of times at the beginning of the cleaning cycle. Did you wait for a while to see if it ends up running the cleaning cycle?
the new machines are kind of freaky the way they work.
later
Apr 09, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Quit . Will not do anything. I checked the power to the machine.
see if you can turn by hand.. the transmission pully and pump pully.. sounds like one of them is bound up, the smell was probly the belt burning with nothing starting to spin
Sep 01, 2007 | Maytag PAV2300 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
