Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Ryobi 40 cc bar oiler not working
Not getting oil to the bar. the end of the hole is not plugedI have the same problem on my Ryobi pcn4040 chainsaw. How do I find the oil filter, etc? I have emptied the oil and shone a torch into the oil tank but don't know what to look for!
  • 3 more comments
  • bjhill Feb 17, 2009
    My Ryobi PCN4040 chainsaw has an oiling problem in that oil will not get onto the chain. I have removed the silencer box and can see the pipework from the oil tank but have no idea how to dis-assemble it to clean it. Advice please.
    Brian Hill
    I have to get at the oil filter on my PCN4040 to clean it(and the oil line) but the instructions given in Solution #1 dated Feb 16 do not seem to apply to my 40cc model.
    Brian Hill
    The solution given by micromaster takes me to a schematic for an electric power saw, but my problem is with a 40cc 16" chainsaw
    Brian Hill
  • Anonymous Mar 22, 2014
    ecs2040 chainsaw was working perfectly and has suddnely stopped. saw is tensioned, oil is okay but not go.
  • Anonymous Mar 25, 2014
    My Ryobi HC410 is not oiling the bar. Trying to fix it. pressing the button to no avail. Do I have to open the motor housing???
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Areas/components to check/clean and ensure no clogging:
  • oil filter
  • oil line
  • oiler pump
  • worm gear drive
  • bar
  • oil hose/feeder to the bar.
For the exploded parts diagram of a PCN4040, pls click here.
Good luck and thank you for using FixYa.
Posted on Feb 16, 2009
The oil pump is located behind the clutch on the oppisite side of the pull cord. the gear that drives the oil pump is more than likely stripped. To access, remove the two nuts that hold the chain and bar on and remove the cover with the brake lever on it, as well as the bar and chain. Next use a screwdriver and a hammer, tap in the direction indicated on the clutch to remove it. Use one of the three spring retainer tabs. Once the clutch is loose it will spin right off. The gray plastic disc is what you are after. pry it out and look at the threads and you will find that they are chewed up. The only problem is that to get this piece, you must get the entire oil pupm assembly which cost 38.00. Good luck.
Posted on Apr 27, 2010
  • Chad Moyer
    Chad Moyer Jul 31, 2012
    You are right. When the small plastic gear gets stripped, it is unable to spin the gear that pulls oil from the tank to the bar. In order to fix this, you must either find someone with a ryobi that is willing to part-out, or order the whole pump assembly.
  • Chad Moyer
    What sucks is that Ryobi would even consider installing a plastic piece like that when that area has the possibility to get jammed. I looked at older Poulans and there is a metal gear instead of plastic. I mean come on; those manufacturers wanted to reduce costs and are going to end up reducing the demand for the cheap manufacturing.
    Brigadier General:
  • 3,614 Answers
Find similar schematics HERE
    Guru:
  • 832 Answers
Hey there!! thanks for using Fixya.com!!
I suggest that you check the oil filter, if its everything fine and then the oil line. Don't forget to check the oiler and the gear as what you said that you are having leak I guess. And also just clean the bar and the oil hose if you have time, and let us see it works.
cheers! thanks! don't forget to mark!!
Posted on Feb 17, 2009
    Sergeant:
  • 326 Answers
Heck the oil filter,the oil line ,the oiler and the worm gear.Clean the bar and the oil hose.
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
  • 19,396 Answers
You can find Ryobi parts and schematics from link below:
Ryobi Parts / Schematics
    President:
  • 1,902 Answers
Take off te pull cord. Get to the clutch. Take the clutch out of both of them (little circle piece), Once you remove the clutch you will then be able to see the line and the oil tank. When you use a chain saw. The wood particles get clogged up inside of the clutch and this will cause you not to get any oil to the bar also the wood chips get stuck up inside the oil line which can be taken care of when you remove the clutch. If this is a electric oil machine then your line is not clogged and the electric oiler has gone bad and needs to be replaced. The reason they never clog is due to the automatic drip system they have they have 3 oil line to oil the bar all the time. So if 1 gets clogged there are still 2 to let oil get to the bar. They also have a self cleaning mechanism in them that helps clean out the oil lines. hope this helped
  • 544 Answers
please find the oil gasket sometimes it is one main reason why the oil not flow properly and
start a saw that was in storage we would install a new spark plug, add fresh fuel mix and spray carburetor cleaner directly into the carbureter to get it started. started fresh fuel would be drawn into the engine from the tank and keep running. don't forgot to drain the old fuel always, also please always check your plug and make it new..
hope i gave you a better solution to fix your problem..
thanks,
    Master:
  • 848 Answers
Oil filter is placed behind the tank in your model .......
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Will not feed oil to the chain bar
Sometimes the oil passages in the bar get pluged up and block the oil. Take the bar off the saw and clean out all the holes.
Dec 18, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw chain brake on Ryobi PCN 4040
remove the cover and check the spring
Apr 13, 2012 | Ryobi Garden
I Have a 26 cc ryobi hedge trimmer. I cannot find any where to oil the thing. I've just been oiling the blades. I know its a 2 cycle but shouldn't there be some where to oil the blades other than dir
check to see if there is any holes in top or bottom of bar to grease or oil, if not there should be screws on bar to remove cover to gain access to blades, also on bottom of engine there is a cover useully with 2-3 screws holding it in. remove cover to grease gear mechanism, do not remove gears inside.
Dec 01, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
Oil not feeding to the chain guide on the electric ryobi chain saw
Remove the cover on the right hand side of the saw and remove the bar and chain. Clean the oil port holes in the bar and the body of the saw. They get clogged with sawdust and chips. Also clean the groove in the bar and the sprocket at the end of the bar. Always use proper chainsaw bar oil.
Jan 12, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
Have Ryobi 40cc 18", have
Release the chain brake and remove the bar and chain. Clean the side of the engine where the bar fits to, then start the engine and see if oil oozes out of the side port on the engine. If it does, then clean the small oil passages in the drive end of the bar that run out from the large holes to the chain groove on each edge. If the oil does not ooze out of the port, then the oil pump, oil line, or oil filter in the tank may need service. Many oil pumps utilize a plastic gear that takes drive from the crankshaft behind the clutch and are prone to stripping the teeth of the gear. Hope some of this helps!
Dec 15, 2010 | Ryobi Garden
HOW do i get to oil pump on pcn4040 chainsaw ryobi
Hello. Although this schematic is not exactly your model it will show you how to get to the oil pump. http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF&app=HML531&session=0ab23ef9-141d-4254-8c9a-35e130708e56&cat=3&TF=epcFrame&assem=5035&ignoreHist=Yes&level=1
That said, many times, the bar and chain oil is too thick for these electric models. Thin yours down with a wee bit of kerosene and it will flow better for you. Joe
4 thumbs up please. ty.
Oct 19, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Auto chain oiler doesn't work homelite temberman 45
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
Timberman 45 does not cross to an IPL I can find. If you can find an IPL it really simplifies disassembly/reassembly, provides component locations and component part numbers. Without the correct IPL I would not undertake a repair.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | Homelite Garden
Ryobi chainsaw pcn4040 - oil not being pumped onto chain, covers have been removed, all sawdust blown out. Oil leaks out under gravity slowly, but when the saw is running no oil is being pumped out. Is...
C. Both A and B. Is it the original bar? Has it ever worked with this bar? Yes continue, no reply below (first). Is there an oiler adjustment?
I know you did this, I have OCD. Good on you for checking.
Oil System Plugged:
I did not see a match to your model. If you can find it the exploded parts list with disassembly/reassembly. Also provide part numbers, where components are located, very helpful.
The 3 models I found all had inboard clutches and the oil pump behind them. Start with this:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Continue like this with the remaining pieces.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
Lou
Mar 10, 2010 | Ryobi Garden
I have a homelite xl, UT# 10655- the chain oil seems to be leaking and coming out of the exhaust and continues to leak after shutting off the chainsaw. Any ideas on the possible cause?
Your saw is listed as an "XL Chain Saw UT-10655" here:
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please take extensive notes & some digital pictures will help during reassembly.
Lou
Feb 27, 2010 | Homelite Garden
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
7,050 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
