FixYa.com
Tags:
Compaq iPAQ H3635 Pocket PC
IPAQ (H3635) will not connect to NT
By Gary10 - usenet poster
Everyone:
I have a problem with my iPAQ H3635. I'm trying to connect the device to my
NT4.0(SP6-a) system, using the Serial Autosync cable(PN: 191008-B21)...I
have downloaded and installed ActiveSync 3.5...It will not connect. I have
tried many solutions to this problem to no avail...My Questions are listed
below:
Will the AutoSync Cable work?
Should I get the Serial Port Cradle?
Tim
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Bray
Bray - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It sounds like my problem, I'm using NT4 (sp6), a serial cradle and
Active Sync 3.5. Also I installed the Fix for First Time Serial
Connection . Still my H3635 only connects once. When the iPaq is
mounted again there's some action with the sounds but it disconnects
within a couple of seconds. To Re-sync the H3635 I have to reboot my
system completely. I also found a util on the net called ASREBOOT.EXE,
but that won't solve the problem either.
Onno Seller
>Microsoft MVP - Mobile Devices
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Try this download from Compaq:
Marc Zimmermann
MVP Information - #
Pocket PC Tips, Reviews, Downloads - #
Pocket PC Info, Works FAQ and Software - #
Pocket PC Users Ruhr, Germany - #
Can you Help with these PDAs problems?
PDAs
archos av500 hard drive...
archos av500 hard drive... Answer This...
PDAs
MY lg chocoale phoen sends
MY lg chocoale phoen sends all... Answer This...
PDAs
i need to know the
i need to know the steps to... Answer This...
PDAs
I have a Palm 750
I have a Palm 750 and it will... Answer This...
need to listen and read only
i have used ipaq3635. only for... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
