Question about Onkyo TX-DS777
Onkyo TX-DS777 Problem biwiring ohm ?
Will biwiring change the ohm rating seen by amp from the speaker
  • gbmsimon Feb 23, 2009
    each speaker has two sets of binding posts
    which is what i meant by bi-wiring a single output from amp
    two wires from one output to two sets of binding posts on one speaker
  • 5,568 Answers
"Biwiring' is not an accepted term; I suspect you mean 'parallel.'
There are three different ways to connect loads (that is all your speakers are to the amplifier);
Assume that the speaker outputs are marked + (plus) and - (minus).
Series - if you connect a + to a - which is then further connected to another plus + which is then connected to another minus, this is a series connecton and if doing this with speakers, each load (let's assume 4 ohms) is additive; in other words 4 + 4 + 4 = a 12 ohm load. The current flowing through each load is identical.
Parallel - In this case, all the + are connected together and then to the + on the speaker connection. All of the - are connected and then also to the minus of the speaker output. In this case, all of the current is shared and not necessarily equally; the lowest load impedance (this is a complex combination of resistance, inductance and capacitance) will draw the most current. If you have all 4 ohm loads, they will all draw the same amount of current. If you have a mix of loads, the final result will be lower than the lowest of the loads.
If a graphical representation is better for understanding, go here:
Series & parallel circuits
In your case, if the output is specified as (for example) 4 ohms and you parallel two 8 ohm speakers, it will be a 'matched load' and safe for the amplifier. If you add a third speaker of 4 ohms, you will have a load well under 4 ohms, below the rating of your amp, and you risk damaging the amplifier if the output is not adequately protected against mismatches.
For your situation, you should look at the math on the Wikipedia link and avoid causing your amp to fail.
Posted on Feb 16, 2009
Tx-ds777 no sound from front speakers on a speakers work on b but if I run a and b the center and surround stop working
Hi MJ, If you run your B speakers you will drop your 2 surrounds as the B speakers are meant to be used in a different room. I would suggest that you give us a call so that we can try some troubleshooting, please call our Product Support Team at 800-229-1687, Thanks, JT
Aug 19, 2015 | Onkyo TX-DS777
Can i connect an ipod to my Onkyo tx-ds777?
You should be able to do it with the right adapter cable.
Jul 21, 2014 | Onkyo TX-DS777
Onky TX-DS777, no sound from speakers
Are the speakers selected for A or B or AB check the speakers by using a 1.5 volt batter on the cable going to the speakers, if you get a sound from the speaker, you know they are ok, if not, speakers are faulty.
Apr 01, 2014 | Onkyo TX-DS777
Kinetic Loud Speaker KA-4260
Kinetic speakers are generally 8 ohm, so they should work fine with the Onkyo.Your amp has a rating of 80 watts per channel, but I'm not sure of the power handling of the speakers.
Feb 08, 2014 | Audio Players & Recorders
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\ good luck
Oct 19, 2008 | Onkyo TX-DS777
Remote problem on onkyo TX-DS777
ya thats the universal remotes having list of codes .
first you set up with the code that should match for your revelent make and model of your dvd player.
so you just go through with codeing list that accompany with purchaseing of universal remote.
and set up with code particularly for your make and model of your dvd player.
and finaly try with your dvd player.
ok all the best.
Oct 08, 2008 | Onkyo TX-DS777
Onkyo receiver TX-DS777
You have a bad amplifier left or right whichever pops if both sides pops then it both amps
Dec 25, 2007 | Onkyo TX-DS777
Same thing happened to our TX-DS777.
Took it to a locate electronic comany and they told us it was the
DSP board gone bad. Est 425.00 to 450.00 to fix.
Aug 16, 2007 | Onkyo TX-DS777
Onkyo TX-DS777 Logo
249 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
