Question about Kenmore 43142 Front Load Washer
Cloths are very wet. I forgot how to make it spin again -no rinse
I've done it before but I forgot. thanks
  • Anonymous Feb 16, 2009
    No spin...clothes are wet. Front loader Kenmore
Set the dial in the rinse cycle and then press the 2nd rinse botton on the right which will go out. Now the washer will only spin at the speed that you set it up without pouring more water.
Posted on Feb 18, 2009
  • 121 Answers
Must have icon on machine it looks like spiral,turn it on.
Posted on Feb 17, 2009
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
Display read suds, cloths wet and waher will not spin.
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cloths still very wet after final spin cycle
Use spin ccyle again for proper operation and to help remove water.
Apr 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Need help please with washer machine,wont spin my cloths,just drn
a belt has snapped or came off or the motor and brushes are damaged.
Sep 20, 2009 | Maytag MTW5700TQ Top Load Washer
Rise and spin
While the machine is operating take the timer knob and wiggle it around. If the machine cuts out momentarily then the timer is bad. If not then I would check out the lid switch to see if it is affecting the rinse and spin cycle.
Eric
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
Cloths still soking wet after rinse cycle
remove the front panel on the bottom look for a screw out filter bout 2 inches long youll see it screw it out clean the filter and reinstall the filter then the water should flow out on spin good luck
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
