Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Where is the lamp housing unit & how do I remove it?
I have a replacement lamp with instructions, but the instructions start after the housing unit has been removed from the TV. The manual refers me to the replacement lamp instructions. So...I got the lower back panel off the TV, but nothing visible looks like the picture on the instructions. Is there a diagram available that would show me where the housing is located inside the TV?
Thanks!I have the replacement lamp, but no directions on how to replace it or reset the hour meter. I sure need both as I am getting the blue thing when I power on tv. Lamp # TY-LA 1000 for a PT -50LC14
  • Terry Cover Feb 16, 2009
  • 217 Answers
Please download the manual for your TV from here:
Panasonic PT50LC14 Manual
Over to page no 81 for instructions on how to replace the lamp.
Posted on Feb 16, 2009
    Genius:
  • 2,920 Answers
You may have to take the back top part of the tv off to find what you are looking for.
  • 8,197 Answers
Go to this link and down load the manual on page 80 it will show you step by step how to replace the lamp.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Give it a min to download the pdf file.
If this is not your tv give me the make and model of your tv so I can help more.
Good Luck and Please Rate FixYa!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Lamp replacement procedures:
  • allow sufficient time to cool the TV;
  • unplug and wait for more than 1hour;
  • remove bottom front panel cover by pulling away from the TV unit;
  • behind the front panel cover with be a squarish cover held in place by screw(s), remove screw(s);
  • behind the cover would be the lamp again help in place by screw(s);
  • pull the handle to remove the lamp;
  • remove lamp from base/cradle;
  • replace lamp, follow directions/instructions included in the lamp box. Note direction/position;
  • move carriage back in following arrow marks to lock it in place;
  • replace cover, replace screw, replace panel cover.
Lamp timer reset procedure:
  • ensure lamp replacement is done correctly;
  • plug in power cord, power on the unit;
  • press and hold VOL - button on the right handside front panel bottom control panel;
  • while VOL - is still pressed, press and hold either the SPLIT or PIP button on the remote;
  • maintain press on both buttons till display shows timer has been reset.
Good luck and thank you for using FixYa.
  • 10,594 Answers
Open lower front of TV , you will see Lamp cover screw, unscrew it and pull lamp cover, there you will see another screw on lamp housing, unscrew it and pull out lamp housing.
    Sergeant:
  • 229 Answers
Full instructions and diagram links are found at :
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
This should help!
    Genius:
  • 2,035 Answers
The lamp unit on your tv is at the front panel of the tv,you need to remove the
front panel under the indicator light ,and then replace the lamp ,please refer
manual from this link :
http://service.us.panasonic.com/OPERMANPDF/PT43LC14.PDF
and refer page no 81...
Remove the Front cover. Place your fingertips
under the Front cover and pull it from the
projection display.
Good luck...
    President:
  • 2,110 Answers
The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
    Brigadier General:
  • 3,614 Answers
what exactly the tv model did you have?
  • micromaster
    micromaster Feb 16, 2009
    How To Reset Panasonic LCD Lamp Timer
    1. Turned the volume all the way up.
    2. Hold the Volume - button on the TV (Not the remote) until it was at 0. Keep holding the Volume - button down.
    3. Press and hold the PIP/Play button on the remote until the message shows the timer has been reset to 0.
    Any further assistance, post back again
  • micromaster
    did the lamp already installed.?
    How To Reset Panasonic LCD Lamp Timer.
    1. Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
    2. Turned the volume all the way up.
    3. Hold the Volume - button on the TV (Not the remote) until it was at 0. Keep holding the Volume - button down.
    4. Press and hold the PIP/Play button on the remote until the message shows the timer has been reset to 0.
    Master:
  • 848 Answers
Hi
first you need service manual for correct instruction.
  • gopinath pasupathy Feb 16, 2009
    you can find screw on the lower back panel of the TV,unscrew it and you can find lamp housing there ...
  • Panasonic Master
  • 19,396 Answers
The housing unit is the cage with the lamp inside.
Jvc tv
FOLLOW this steps and fix it. God bless you
  • 1
    Power down the TV. Let it cool down for several minutes to avoid touching anything hot. There are many parts inside the TV that could be hot.
  • 2
    Unplug the TV and all media devices attached to it. Let the TV sit again for several more minutes just to be safe. The lamp receptacle and other components could still be hot.
  • 3
    Unscrew the back cover of your TV with a screwdriver. Have someone help if the cover is big. The lamp's housing unit on most TVs is located towards the bottom. Refer to your TV Owner's Manual for specific instructions.
  • 4
    Unscrew the lamp's housing unit with your screwdriver. Take your time to avoid damaging the housing unit. You'll see the lamp once you open the housing unit.
  • 5
    Use a soft cloth to unscrew the lamp out of the housing unit. There's a possibility the lamps- could still be hot. The cloth will help protect your hand.
  • 6
    Screw the replacement lamp into the housing unit with the same soft cloth. The oils from your fingers could ruin a rear projection TV bulb.
  • 7
    Reattach the lamp's housing unit and TV back cover. Make sure no wires are loose or get caught when screwing the back cover on.
  • 8
    Attach all media devices like cable or satellite boxes. You should now be able to watch your TV with a brand new picture.
Jul 25, 2013 | Televison & Video
How do you replace the lamp for a panasonic PT-50LCZ70
Hello
To replace the lamp of your Panasonic Projection TV do the following. Read these instructions carefully and then try to do the job.
1. Turn the power off, wait until the power indicator turns off blinking red, then unplug the power cord from the wall outlet and confirm that the area around the lamp unit has cool down.
2. Remove the front cover procedure. Place your finger tips under the cover and pull it from the projection display.
3. Before loosening the lamp cover screw, first read the caution and warning labels in the lamp cover. Then loosen the lamp cover screw by using a screwdriver.
4. Loosen the lamp unit screw with a screwdriver. Then grasp the lamp unit, Figure 2, by the lamp unit handle and slowly remove it from the projection display.
5. Insert the new unit being careful being careful of the insertion direction. Press in the arrow mark making sure insertion is done correctly.
6. Replace the lamp unit and cover screw. Tighten the unit cover screw with a screw driver.
a. Properly dispose of the old lamp. Please see the operating instruction of the projection display unit.
b. NOTE: attached the lamp unit and lamp unit housing door securely. If the lamp unit and the lamp unit housing are not attached securely, the protective circuit will be activated and the lamp will not turn on.
7. Replace the front cover.
The second step, after lamp replacement is to follow the three steps procedure described below:
Warning: Perform lamp time reset only when the lamp has been replaced.
In order to complete the lamp time reset procedures:
1. Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button the projection display or the remote control to turn the unit on.
2. While pressing the VOL - button, hold down the PIP or the SPLIT button on the remote control at the same time for more the 5 seconds.
3. When the reset procedure is complete, the projection display screen will show the following message "Lamp time was reset to 0."
Notes:
1. The writing in the screen may be different from the actual screen described above.
2. When lamp time reset is finished, the lamp indicator goes out.
OK.
Feb 23, 2011 | Panasonic PT-50LCZ70 50" HDTV
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Nov 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
    Xl-2100u
  • Unplug your Projector from your power outlet
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    Lamp out ...
    remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
    Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
    Removal of projector bulb housing
    Here is a better site for instructions. It has a .pdf file.
    http://www.911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
    Feb 21, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Jaime Hernandez
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
