Question about Samsung HP-S5053 Television
Top half of screen going black.
I have a Samsung 50" Plasma (HPS5053x/xaa). It worked great for the first 2 years, but the top half of the screen just started flickering and going black. Any help would be appreciated. Thanks.
  • ecaribe Feb 16, 2009
    I have the same problem,half of the bottom screen goes black and flicker and then the whole screen is dead.please help email at ecaribe@hotmail.com
I've seen this or something similar to this problem on an old lcd screen. The bulb haden't burned out but the system was no longer getting proper 5 volts to the processor chip that processed the image. I ended up desoldering the voltage regulator and soldering a new regulator in it's place it was one with the same amperage so I put a heatsink on it to reduce the chance of another failure.
Posted on Apr 11, 2009
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
My samsung 50 inch plasma tv has a black and white 2 inch stripe from top to bottom one third from the left side of tv our tv is about 1.2 years old is there a addjustment to be done ? thank you from mike
Image retention, Go to Menu and I believe pic settings go to the Burnin Scrolling feature..Will run white and black in full screen, run for an hour problem huold be solved..Happened to mine and the scrolling feature got rid of it.
Mar 15, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
My samsung tv model hps5053x/xaa is not finding my laptop via hdmi. i have been using it this way and then all of a sudden it isnt recognizing it now. what do i do what is the issue?
have a samsung plasma model HPS5053X/XAA i have it for less" -- because it falls within my area of expertise. I just need a few more details about your situation and I will get to work!
Jan 05, 2011 | Samsung HP-S5053 Television
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
Aug 27, 2009 | Televison & Video
50 inch samsung plasma that is 3 years old occassionally gets a black bar across top half of the screen. is this tv done?
not necessarily, sometimes the connectors that feed the screen get old and dirty
If you have some electronic skills, open the TV and clean the connectors around where you see the symptoms and you may have a good chance to get if fix by doing that...
good luck
Jul 13, 2009 | Samsung PS42S5H 42 in. HD-Ready Plasma...
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
May 20, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
705 people viewed this question
Jerry Greenberg
Jerry Greenberg
