Question about Kenmore 24032\24036 Top Load Washer
Won't Spin, does pump
Washing goes through cycle but doesn't spin
  • 135 Answers
Check the coupling between the motor and gearcase. Hope this helps!
Posted on Feb 16, 2009
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
Spin cycle will not work on siemens xlm 1400 and filter has been cleaned what to do
If the spin cycle is not working, it could be several things. How is it not working? If it won't do anything, i.e. doesn't turn, then I would suspect the transmission since the spin cycle is the high side of the transmission. If it spins but does not take the water out of the unit, then I would suspect, either the pump or the timer.
Good luck and have a great day!
Jun 09, 2011 | Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Wm2455hw will not spin
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Apr 22, 2011 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
22 people viewed this question
Sal De
fordexpert
Robert Rankin
