Question about Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
My mother's duet dryer just started making a loud mechanical whining noise. It does not sound like a rubbing noise you would expect from a belt...the dryer is about 5 yrs old. I am just curious if anyone has experienced anything like this. It still heats like it should...just makes the noise. Thanks for any replies!!
  • 3 Answers
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Posted on Feb 25, 2009
Whirlpool duet dryer belt squeeking
needs replacment theres no adjusting that belt, are u sure its the belt and not the rollers? or drum glides?
Sep 28, 2014 | Whirlpool Dryers
My dryer is making a very loud squeaking sound when I turn it on. Also inside is very hot within minutes.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My Whirlpool Duet dryer is making a loud squeeling noise when drying.
Hello, the squelling noise from your dryer may be coming from the drum rollers. May need to be opened up and lubed. It can also be the idler pulley, also can be lubed. Disconnect power, remove lower panel, and see if you can isolate the noise. Oil where necessary. If you can't get to it, the drum wil need to be removed. If something is locked up or damaged, it will need to be replaced. Caution: Don't stick fingers near moving parts when running :-> Hope this helps, Rich
Jul 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool GEW9250 Electric Dryer Logo
928 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
