Replace Contactor Relay on Rheem Air Condenser
I am replacing the double bareel 24 amp contactor relay switch in my Rheem air condenser. I purchased a non-Rheem contactor switch that is also double barrel and 24 amp. However, the connections do not match the original switch. Do I plug in the conncetion on the corresponding sides or is this much more difficult? Help please.
I have a Rheem heat pump/airconditioner, Mod # RPFA-036JAS, that I have had problems with for at least 5 years and have paid over $1,000 in parts and service calls. I can vever recreate the problem when a tech is here. It usually happens in the middle of the night. I hear a Click, ckick, click sound, through the unit and it sounds like it is comming out of my air handler, but the outside unit also clicks at the contactor and the condensor cooling fan moter will start and stop about every half secongd or second. Both contactors have been replaced, the small one twice, one capaciter
has been replaced. I allow the unit too cool down and its alright for a few hours. That is difficult when the outside temp is below zero. HELP PLEASE!
Posted on Dec 10, 2009
REPLACED BLOWER MOTOR ON LENNOX NOW THE FAN WILL BLOW FOR A BIT BUT THE COMPRESSOR DOESNT COME ON TO START COOLING
Posted on Mar 28, 2009
  • 56 Answers
You just need to go wire for wire on the contactor. You can also draw a wire diagram to make sure wires go into same spots.Make sure power is off for safety purposes. As long as amperage of contactor and voltage of coil is correct you should be fine.
Posted on Feb 16, 2009
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
We have royal red furnace to heat our home.The fan dose not stop.
Details.......does the furnace function normally otherwise? Might just be a stuck fan switch. Make sure the thermostat hasn't been set on Fan ON setting or summer air circ. on older furnaces.
Find the fan switch and tap it and see if fan quits. If it does,fan switch is bad.probably. Always make sure your air circ. filter(return air to furnace) is replaced every 3 mo. or so,too. don-ohio (:^)
Jan 03, 2017 | Royal Heating & Cooling
How to bypass the relay on a Reddy M100D
Best change the switch ,than bypass it .
Jan 03, 2017 | Reddy Heating & Cooling
Cooloing is not coming down from room temperature
The unit needs service. Call a technician! You can:
Check your air filters
Clean outdoor coil by turning off all power at breakers and tstat, clean o.d. coil with water hose
Inspect indoor coil (if you can) for build up or debris
Other than that? May be low on freon. A service tech will cost $ BUT not having the unit service will cost more due to electrical consumption and excessive run times shortening the life of the system.
Jun 24, 2015 | Heating & Cooling
Only recently my portable heller air conditioner is oosing out buckets of water each night. does it mean it finished and needs replacement,
Portable air conditioners cool the air, and in so doing, dehumidify the air. The "buckets" of water are coming from the humid air in your environment, so you need to do things that will reduce humidity, of be prepared to empty the condensate receptacle fairly often.
Using a small room, closing doors and windows to the room you want cooled, avoiding cooking or heating water, reducing the frequency of people walking into/out of the room and limiting the number of people in the room will all help in reducing, and keeping low, the ambient humidity.
Jan 03, 2015 | Heating & Cooling
Water leaking out the front of inside unit
It may be tipped too far forward or the drain port is plugged and not allowing the condensation to drain properly.
Jan 23, 2014 | Heating & Cooling
A/c fan not working=thermostat is working(central a/c system)a/c
The fan on the outside unit is powered from it's 240 volt source. Check that the breaker for the outside unit is not tripped. Also, a contactor is inside the outer unit that starts the fan - it may be faulty.
Jul 26, 2008 | Friedrich QuietMaster Electronic SS12J30D...
Heating & Cooling Logo
2,355 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
