Question about Hitachi 53UDX10B 53" Rear Projection Television
HITACHI 50DX01B IT SHUT OFF AND WON'T POWER BACK ON
THE TV SHUT OFF WHILE I WAS WATCHING AND WONT POWER BACK ON. I'M WONDERING IF THERE ARE REPLACABLE FUSES INSIDE THE TV. ANY HELP WOULD BE APPRECIATED. THANKS!
  • Anonymous Feb 17, 2009
    My Hitachi 50DX01B shut off while I was watching and now it won't power back on. There are 6 small diodes that light up when I plug TV into the outlet, but they go out after 2 seconds. None of the resistors are swelled up and the fuse is good. Any solutions would be appreciated. Thanks!
  • Hitachi Master
  • 5,138 Answers
Yours is not a fuse problem replace Both of your STK ICs they are big black ics will have part number on them If they are 392-110s use 180s.Also 6 resistors to replace with them RK42-46-50-54-58-62.
Posted on Feb 16, 2009
I was watching my Hitachi 42hdm12 and heard a pop and now the picture won't show up or sound or anything?
A pop is usually a power surge and you blew a board. If you take the tv apart, if this is it, it will be evident by the burn marks. You could have burned out the internal power supply as well.
Oct 04, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
You didn't do anything to cause this. The thing is that there are several possible causes for this problem. They include convergence circuit failures, power supply/regulator issues and deflection/high voltage malfunctions. The only way to determine the cause is to have an hitachi authorized servicer out to diagnose this. Be aware that the repair costs could be $300-$600 depending on which circuit is causing the failure.
It might be time for a flat panel LCD!
michtech
Feb 17, 2009 | Televison & Video
HITACHI BIGSCREEN TV MDL 57TWX20B APPROX 4-5 YEARS OLD...TV SHUT DOWN WHILE WATCHING AND WON'T POWER BACK UP
This can be one of two problems. 1: convergence output ic's need to be replaced. 2: The problem is in the power supply, most likely a power diode.
Both problems you will need to take it two a repair shop.
Mar 15, 2008 | Hitachi 57TWX20B 57" Rear Projection...
No Power
Yes take it to a repair shop . unless you know how to repair it.tv has power supply problems shorted hori out put transistor.open pico fuse 5amp etc...ect,,,ect.....Its hard to say what might be wrong with your tv untill trouble shooted by techician.
Jan 27, 2008 | Hitachi 50DX01B 50" Rear Projection...
Hitachi ultravision tv
tv comes on ,i hear but can not see
Dec 27, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 27AX1B immediately shuts off at startup
you are going into shut down check regulator check for bad solder connections get back to me
Nov 02, 2007 | Hitachi 27CX01B 27" TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
170 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
