Question about Olevia LT32HVE 32 in. LCD Television
Syntax Oleiva 50 in. LCD tv
My Syntax Oleiva 50 in. LCD tv model number LCT50HV keeps turning off. It blinks red and green until I cut the power and after sometime it will restart. I have replaced the bulb and it still turns off. What can I do to solve the problem?
  • Olevia Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
Once we turn on the power, the power light blinks green 7 times and then blinks red 3 times. Aftern the pause 3 red blinks again. What type of problem is that? What parts do we need?
What I would suggest is go onto ebay and put in the model number of the t.v. and then the word lamp.
It should come back with the proper lamp replacement model numbers.
Apr 25, 2014 | Sony Kdf-e50a10 50-inch Lcd Rear...
LCT50HV black screen and blinking red/green lights
Replace your Bulb which is located on the side panel. U can do it yourself and save some money.
May 19, 2009 | Syntax Olevia 50" Rear Projection...
Syntax Oleiva 50 in. LCD tv?
Lcd tv's do not have color wheels in them, only DLP sets have them along with projectors. DLP sets are the ones with the single lamp, color wheel, light tunnel,,ect...Send me your Model number and the problem your having, I'll do the rest....
Feb 14, 2009 | Olevia LT32HVE 32 in. LCD Television
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Olevia 50" rear projection problem
http://www.tvlampsforless.com/Olevia_LCT50HV_bulb_p/lct50hv.htm
Apr 08, 2008 | Syntax Olevia 50" Rear Projection...
Lamp
Jan 08, 2008 | Syntax Olevia 50" Rear Projection...
Olevia LT32HVE 32 in. LCD Television Logo
135 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
