Question about Nintendo 64 Console
Ho to fix a loose joystick for a n64 controller?
It is loose and wont work
Theres a part inside that you ave to replace a plastic part you can order somewhere online for about 8 dollars but your goign to have to open the controller up or get somebody to do that for you.
Posted on Mar 24, 2009
  • 265 Answers
Just take it apart and see if you can tighten it,
if not you will have to pick a new one up
Posted on Feb 16, 2009
How can i connect an super joystick tv game to iMac
As the Super Joystick TV Game (N64 Famiclone) has only TV output, you can only connect it to a TV or an external USB TV tuner.
Nov 23, 2013 | Apple Computers & Internet
Fisher plow gets power to lights but wont lift or turn, Any ideas?
Fisher needs a good contact loose contact start from the battery and work your way around everywhere theirs a connection
Dec 28, 2012 | Fisher Minute Mount Plow Joystick...
N64 Conroller Wandering
Do not move/touch the joysticks on the controllers while turning on the system.
Jun 25, 2012 | Nintendo 64 Controller - Original Gray
My joystick on my n64 controller is loose . on my legend of zelda ocerina of time my person is walking slowly can u help me fix my controller.
The Nintendo 64 was probably the first system to introduce the Analog Joystick. The joystick unfortunately does wear out after a while. I have seen repair sticks available on the internet, but that would require opening your N64 controller to replace this part. OR you can simply buy a new controller. The following website sells them for around $17 free shipping:
Jun 16, 2011 | Nintendo 64 Console
I have a problem with my psp1000.when i remove the joystick and i try to play a game use only a character just keep on running in left direction and i cant control's like it has a mind of...
The reason your character is moving by itself is your joystick malfunctioning. This is due to long playtime and hard pressing of joystick. It could also be that it has dust in it that's why it's malfunctioning. If it is still under warranty why don't you bring it to the nearest shop and let them fix it for you. You can also clean your joystick first from any dust and check if it solved your problem. Try watching this for your guide in cleaning the joystick of your psp. Be very careful in doing this or it might make your problem worse. If you want you can replace your joystick, I have checked it ebay and the price range from $2 - $3..
I hope this helps. Have a nice day!
Mar 08, 2011 | Sony PlayStation Portable (PSP) Console
N64 AV port loose, does not work
push in harder if does not work blow out socket alternatively, contact nintendo
Jul 14, 2009 | Nintendo 64 Console
I have a invacare The joystick mk5 will not lite up batt. are new
Some chairs, like the M91 are a real bear to replace the batteries and connectors can get knocked loose in the process. First, using a voltmeter you need to see if the controller is getting power. On the DC setting, use voltmeter at the three-pin female connection at the joystick that is the charging port. The two pins that are opposite each other are the "hot" pins, and your meter should read about 25 volts, +- 2 volts. If its 0, there is a connection that isn't made from the batteries through to the controller, or the controller or joystick is shot. If you do have power to the joystick, then it's probable that the joystick is shot. A new one from Invacare is pricey, around $1,000.00 I have found a new site that can repair most makes. I have not used them, so cannot vouch for their work, but give them a call and see what you think.
If you don't have power, start at the terminals from the battery, and follow each wire back to the power control box, unplug and replug firmly as you work your way back. Check all fuses on the way. Then check all of the other connectors inside the chair, unplug, and reconnect again. Unplug and reconnect the wires leading into the power control box, and then restart chair. If no lights still, then the power control module is probably the culprit, but the address above fixes those too. The joystick and the power control module work together to make the chair operate safely. Good luck
Jun 19, 2009 | Electric Jazzy 1115 Power Wheelchair
N64 wont turn on... i miss it
Had the same problems.. the n64 just turned off after playing dr. mario for a few minutes... anyways, heres what worked for me
1. make sure your wall outlet works *sounds dumb, but better safe then sorry, plug in a light or something to make sure it works*
2. unplug EVERYTHING, controllers, vid cord, power etc
3. let everything be disconnected for about a minute or so, the AC adapter sometimes overheats and turns it self off which might be the problem.
4. ONLY plug in the AC adapter to the n64, make sure its firmly plugged in. turn it on.. it should light up now, if so, plug everything back in. enjoy :)
Aug 29, 2008 | Nintendo 64 Console
Broken GC controller
yes you can. but only though the internet.
Mar 07, 2008 | Video Game Consoles & Games
Nintendo 64 Console Logo
2,852 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
