Question about Bang and Olufsen Beocenter 9300 Shelf System
Beomaster 5000 receiver, no sound out of left side
No matter what your running thru the receiver there is no sound out of the 2 left side speakers, only the right side. Am I missing something or is the unit broken? Everything is hooked up correctly and I know that the other items all work. What could the possible problem be and what might be the solution?
  • 122 Answers
If you connect a pair of sp to sp2 outputs only and the l/h is dead check balance on mcp5000 it may be over to the right.
Posted on Jan 11, 2010
Just purchased a home that has an Onkyo THX Select 2 Surround EX receiver with Bose Surround Sound speakers. When I attempt to turn the unit on, it hesitates a few seconds and then makes a dull click with...
So, it has NEVER worked? Review your connections regarding the speakers.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 02, 2011 | Onkyo TX-SR803 Receiver
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
What type of speakers and turntable work best or will work with a Bang & olufsen 2400 reciever and 6000 reciever. thanks
I believe this Beomaster series needs amplified speakers that goes with it. You might use the RCA out and make it amplified with another receiver or amplifier and use ''usual'' passive speaker.
Oct 08, 2009 | Audio Players & Recorders
Beomaster 5000 no sound out of left side
there is probably an internal fault but check that the pre out main in links are both there and the sockets to them are properly soldered.
Feb 16, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
BEOMASTER 4000 No sound from one speaker. Tried swaping cables etc.- problem lies in the output from amplifi
Hi...
Try one other thing..headphones. If there's only 1 channel in the headphones then you'll need to take it to a tech.
Depends on where in the country you are as to a good tech.
I know some...even me in the Northeast
Jan 11, 2009 | Audio Players & Recorders
No sound from speakers
This is caused by the Thermal protection device inside.
First Unplug the Reciever, let it cool for about 15-30 Min and then
Check all speaker wires to make sure they are in good condition,
no fraying wires or loose .
Plug in the reciever, make sure there is nothing on top of it,
(also do not have a shelf directly over it, you need a good 8" of
clearance above it for adequate ventilation..
Now push and hold the Reset button on the left side of the front panel
and see if this restores it.
Another thing to try is, get a can of compressed air for computers and
try blowing out the dust thru the vents on top and sides of the case,
Note ** (Do not open the unit to do this)
Jan 03, 2009 | Technics SA-DX950 Receiver
Input LP's to my computer & play thru X-Fi sound card
Digitizing sound does not improve its quality. If your LP's sound like they do when you just play them through a stereo then the sound card is doing its job, which is to reproduce audio. If you want to change the way it sounds look into software to buy to do so. But simply running it throuch a analog to digital converter will not make it sound better when your source is an LP
Dec 06, 2008 | Acer Aspire™ T180 PC Desktop
Sound distortion on beomaster 3300
There is a defect in the pre-amp section of the unit. Without seeing it and taking a few measurements, I can't give you any particulars. A rough estimate for a repair wouldbe about $10-$25 in parts plus the local labor rate.
Dan
Sep 30, 2008 | Audio Players & Recorders
Left side speakers only one working
Have you reset the settings in the system to 5.1?Are the rest of the speakers working? Go over the wireing yourself just unplug one at a time and reseat it on both ends system end and speaker end it may just be that when he put it together again one of the wires wasn't set back just right.
Jul 14, 2008 | Onkyo TX-DS676 Receiver
281 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Iron
Iron
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
