Question about Whirlpool LER5636P Electric Dryer
DRYER WILL NOT TURN ON
THE TIMER HAS POWER BUT THE DRYER WILL NOT TURN ON
  • Bill Sam Feb 19, 2009
    it was a fuse on the back of the dryer that would not let the motor start it cost 16.99 and the dryer works well.
  • danirhia Feb 21, 2009
    I have a Whirlpool dryer with the same/similar problem. Where do I find the model number to see if its the same model as this string? And, if its the same model where is this fuse located?
    Genius:
  • 1,122 Answers
Check the door switch and the main fuse behind the back panel and let me know what you find-mike
Posted on Feb 17, 2009
  • MIKE major Feb 19, 2009
    did you leave me a fixya rating?thanks-mike
    what s with this thanks for trying rating?i lead you right to the problem,please chance your rating so my master rating stays the seem-mike
My maytag atlantis gas dryer will not turn off at the end of the cycle
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Mar 23, 2016 | Maytag Dryers
Timer won't stop after cycle finished.
May 20, 2015 | Dryers
My LG Dryer still runs when it is off and when I turn it on it says to check filter
Sep 23, 2014 | LG DLEX3875V Dryer
Fisher Paykel dryer won't shut off. Dial not moving. Would this be the timer, sensor, or soething else?
Sep 21, 2014 | Dryers
How to fix aFisher & paykel dryer coils are on when dryer is off?
Aug 22, 2014 | Dryers
Hand dryer won't shut off
will not shut off:
Aug 14, 2014 | Dryers
GE Profile dryer keeps running and timer switch doesn't move
Aug 13, 2014 | Dryers
Dryer works but when time is up it keeps running (cold air)
Aug 13, 2014 | Kenmore Dryers
Dryer won't turn on. the breaker is on
Do you have a multimeter? I would suggest unplugging the unit and checking to see if there is power at the plug. If there isn't any power then I would say the breaker is defective. If you do have power, then take the back of your control panel off and check if you have power to the timer control. To double check the timer, turn to a dryer setting and see if there is power at the motor. If the meter shows power there then the motor is not working but the timer works.
May 17, 2009 | Maytag Dryers
Electric dryer wont heat or turn off
there could be a temperature switch that tripps off. look at the diagram and trace also the power to the timer motor. it seems that you lost your power to your timer motor that is why the timer stays @ what ever setting you set it.
Feb 11, 2008 | Kenmore 63942 Dryer
Whirlpool LER5636P Electric Dryer Logo
66 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
